Results 1 to 6 of 6
Thread: Windows 7 64 bit issues
    Jul 2006
    Barrie,Ont.
    28
    I can't get the editor or scanner to work.
    I down loaded the lateset version from the HP tuners website.
    I tried running in compatability mode (xp service pack 2) and it doesn't work.
    Whice Net.frame work should I be using??
    The 2.0 doesn't work on the 64 bit system.
    Jul 2006
    Barrie,Ont.
    28
    I have the right drivers installed,so I don't think that is the issue.
    Every time I go to start the editor or scanner I get the message:
    Editor has stopped working and needs to close.
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,288
    Maybe an antivirus or other program creating a conflict. Fresh install of win 7 ultimate 64 works fine for me.
    Jul 2006
    Barrie,Ont.
    28
    I un installed then re-installed hptuners and it worked....for a bit.
    After I closed the editor it won't re open.
    Jul 2007
    AUSTRALIA
    180
    I have had that when doing updates Just Re-Run the installer and it will give you the option to repair. Select that and it should fix it.
    Jul 2006
    Barrie,Ont.
    28
    I went through my AV and started dis-abling components one at a time and found one that was conflicting with HP tuners.
    "Code injection performance",prevents programs from gaining acess to system privileges.
    As soon as I dis able this feature it began to work.
    Thanks to all who helped.
