Anyone have an idea why my WOT AFR would be 10.4-10.5 when commanded was AFR was 12.5? Nothing was changed in the tune. The tune was spot on and has been for some time, but I was at the track and the car started slowing down on me. I checked the scan and noticed the AFR was really rich (mid 10's). Before this happened the AFR error was within 1% of wideband on the street and on the dyno.
The temp was about 10 degrees hotter than when I was on the dyno, not sure if that makes a difference. Car is an '06 vette, running MAF only tune. COT is not enabled.
I've attached the scan. The issue starts at frame 2760.
