Results 1 to 6 of 6
Thread: No RTT for 3 Bar OS on a 04 Vette
    Tuner Mike04's Avatar
    Feb 2007
    Orange Park Fl
    104
    I upgraded from a 2 Bar OS with RTT to a 3 Bar and there was no RTT option. Did I miss something or is it not available?
    RHS Block 427, Mast/ PI 275 Heads, A&A YSi SC, 3.125Pulley, 238/254 LSA116+5, Flip Drive, AR 1 7/8 Headers, Corsa Touring Cat Back, RPM Level VII Tranny/ Flexplate/ Drive Plate, PFADT Carbon Fiber Drive Shaft, RPM rebuilt DTE Stage 4 3.42s, Vigilante 3 Disk 2600 converter, Custom Fuel System with Dual A1000 Pumps, ID 1000 injectors, Triple Nozzle Alky Control, 3 Bar SD Tune using 2.5 MAP. 935rwhp 800rwt
    Feb 2007
    Orange Park Fl
    104
    Anyone?
    I had the same thing happen to me with my truck. Apparently the OS you're probably using doesn't support it. A different OS probably will, but as I was told, you'll need to burn another 6 credits to get it (2 for 3bar, 2 for RTT and 2 new OS). You could try and ask if HPT will help you out. I'd like to know as well since I greatly miss RTT.
    2000 ECSB Sierra, with a lot of tuning to do.
    28,268
    Post your stock .hpt file
    Feb 2007
    Orange Park Fl
    104
    Bill,
    Here is my old tune prior to the 2 bar and 3 bar OS. Anything you can do to help is appreciated.
    28,268
    The 1 bar SD, 2 bar SD & 1 bar maf w/rtt all come with RTT. The 3 bar custom os doesn't and we won't be adding it. So if you want RTT you would need to use the 2 bar custom os in this case otherwise you'll need to just have to deal without it if you absolutely need the 3 bar support.
