I'm installing a 2005 E40 Trailblazer ECM that is programmed with a 4wd VIN. How do I change it to run a 2wd transmission in my project vehicle?
You will have to find someone with a tech 2 to fast in a 2wd calibration with your vin number.
Ian
2008 Corvette A6 - Comp Cams 231/239 617/624 109 ICL 113 LSA, Patariot Extreme Dual Springs .660", Milled .30" Stock LS3 Heads, Mahle -4cc pistons, FTI 3600 Converter, 1 7/8 kooks cat-less 3 inch X-Pipe, air raid intake, ported TB, SLP Loudmouth I. 512hp/464tq
2011 Ford Taurus SHO - stock with just a Tune
