Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 65
Thread: using the transient (dy/dx) filters
  1. #21
    Senior Tuner Frost's Avatar
    Jan 2006
    Richmond VA
    1,950
    I'm waiting up tonight for the answer
    Steve Williams
    TunedbyFrost.com
  2. #22
    Dec 2005
    214
    Quote Originally Posted by Frost View Post
    Me to!!
  3. #23
    Dec 2008
    on the Dyno
    1,825
    I've not had the chance to tinker with this yet. Hopefully I can help test and give some insight on it.
    Located in Central Kentucky
    ShorTuning
  4. #24
    Jan 2006
    Richmond VA
    1,950
    ahhhhh I need to know the answer to this!!
    Steve Williams
    TunedbyFrost.com
  5. #25
    Dec 2004
    Laurel, MD
    1,020
    do we get an option for how many frames/seconds our 'window of change' is?
  6. #26
    Senior Tuner S2H's Avatar
    Apr 2005
    4,387
    per a talk we had in the moderator section...
    should be dx/dt
    use could be something as simple as [send.90.dx/dt]
    it reports the difference in TPS +/- from the last frame..
    currently no option to change the amount of frames it uses...
    -Scott -
  7. #27
    Jan 2006
    Richmond VA
    1,950
    abs([PID.17.dy/dx])
    or
    [PID.17.dy/dx]
    Returns actual TPS with two decimals. This is not what is expected.
    edit
    you mean literally that dx/dt need to be used...
    Steve Williams
    TunedbyFrost.com
  8. #28
    Jan 2006
    Richmond VA
    1,950
    No, using dx/dt returns the same (actual value) as dy/dx with or without (obviously but just mentioning) ABS.
    Steve Williams
    TunedbyFrost.com
  9. #29
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    Quote Originally Posted by soundengineer View Post
    should be dx/dt
    The change since the last frame would be ideal. It'd be the easiest for people to understand, too.
    http://www.dsxtuning.com
    Just say no to bull s***.
  10. #30
    Dec 2004
    Laurel, MD
    1,020
    ideal is not the word you're looking for, more like 'inflexible.' some things change quickly, others change slowly, so you have to regulate the duration of the change, cant just rely on fixed and arbitrary intervals.
  11. #31
    Mar 2008
    St. Louis, MO
    4,860
    I'll rephrase... for what I want to do, the change since the last frame would be ideal.
  12. #32
    abs([PID.17.dy/dx])
    or
    [PID.17.dy/dx]
    edit
    i need to check with Keith, sounds like something is broken. you need to use dy/dx when you spec the formula. I have discussed with Keith changing it to read dx/dt in future as this is what it *should* be.
    I count sheep in hex...
  13. #33
    Mar 2008
    St. Louis, MO
    4,860
    Quote Originally Posted by Chris@HPTuners View Post
    So it's definitely change in the parameter divided by the time since the last frame... at least, that's how it's supposed to be?
  14. #34
    Dec 2004
    Laurel, MD
    1,020
    so with the syntax available, how would I express 'change of change?' Laplacian of Gaussian is a common noise reduction technique, which would be hugely useful to us.
  15. #35
    Jan 2006
    Richmond VA
    1,950
    Quote Originally Posted by redhardsupra View Post
    I have used LoG playing with images in the now far past...
    I guess you could define the first portion as a transient user PID and make a second user transient PID which examines the first..
    Steve Williams
    TunedbyFrost.com
  16. #36
    i discussed this further internally and i think the best way to go with it in future will be to simply have a reference to the previous frame value of any PID and also the time between frames eg. [PID.17.old] and [PID.17.time] or something similar.
    This way you can implement derivative functions, simple lag filters using any coefficient you want and any other formula you can think of without needing us to code it in.
    eg.
    FastFilteredValue = PID.17.old + (0.9 * [PID.17 - PID.17.old])
    SlowFilteredValue = PID.17.old + (0.1 * [PID.17 - PID.17.old])
    DerivativeValue = (PID.17 - PID.17.old) / PID.17.time
  17. #37
    Jan 2006
    Richmond VA
    1,950
    Is there any other information on this feature?
    Steve Williams
    TunedbyFrost.com
  18. #38
    Apr 2005
    4,387
    eg.
    I like the idea to code it as a variable that you can change...
    perhaps a setting for dt somewhere in the main options section of the scanner
    dt= ___ Frames
    then it could be used as pid.17.dx/dt and it would automatically return a value based on the difference from the dt value set in the options
    as an example dt=5 would return the change in value over 5 frames
    we could also use a way to average things..so you could get the average change in real time vs plotting the average in the scanner...
    sometimes it would be better to get a constantly updated average over a given period of time vs the total average for the entire log.
    Maybe an Average over time setting? AOT=600 would return the average over 600 frames...continuously updating...dropping early values ad keeping the latest values
    -Scott -
  19. #39
    Mar 2008
    St. Louis, MO
    4,860
    This would be awesome. I've often tried to make this possible with what's available, but if it was a simple feature, it'd kick ass.
  20. #40
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,772
    Are there any updates on how to use this feature? .
    Thanks,
    Ed M
    [email protected]
