I just finish installing a 2000 F-Body LS1/ 4L60E into a 1984 Vette. I also swap in a 2000 C5 Vette dash /cluster so I would have a turnkey display. Everything is working (speedo, tach, engine temp, voltage) but some of the serial data like the fuel level & oil pressure is not. I have a 2002 F-Body PCM . The pin out between the F-Body & 2002 Corvette PCMs look the same except the corvette have extra options. I tried adding the corresponding pins for the fuel & oil pressure gauge but the serial data is still not getting information to the gauges. All the other serial data is being display on the C5 cluster: tire pressure, coolant temp, oil temperature, etc.
I figured the 2002 Camaro PCM would be identical to the 2002 Corvette , but maybe it’s not or is there somewhere on the HP tuner S/W I need to add these functions. I look around but couldn't find anything. The fuel gauge should at least work? Transducer Ground issue?
Does anyone have any ideas?
Thanks,
Dan
