just to get something clear, i hook up the white wire (5volt output from wideband) to the #1 pin on my mpvi pro ? i do not need to hook up the ground to it or anything ?
also what numbers do you use to set up the aem wideband, i have seen that the lc widebands are somethink like this
0 volts 10.0 afr
5volts 20.0 afr
so what are the numbers for the aem wideband ?
