Page 1 of 5 12345 LastLast
Results 1 to 20 of 93
Thread: Idle, Throttle Follower, and Throttle Cracker
    Mar 2010
    Texas Hill Country
    3,299
    Ok I have searched around all day yesterday but could not find this info (which I am sure someone will link me directly to, lol).
    I ran RussK Idle config for RAF and got the numbers very close. And it seems to idle well once fully warmed up. However, if I let it cool to say 160 or something other than 195, it won't idle well at all and surges/dies/etc upon startup and while driving. Also, when it is fully warm, if I start it to pull from driveway to garage and let the clutch out and quickly put it back in (since I am going 20 feet) it dies and coasts into the garage.
    What do I need to do? Manually increase the values in RAF?
    Also, when I log TCracker, what PID do I use? And TF? Is there a histogram I can use to edit these tables? I tried STFT but that did no good....
    Thanks!
    I have a ETC (so what do I do with IAC tables?), a 2001 Z06 OS converted to 1 bar MAF RTT, a 408 with 236/244@114 cam.
    Advanced Tuner 69lt1bird's Avatar
    Oct 2007
    983
    Since it is doing this in Open Loop fueling because of the temp, have you tried adjusting the Open Loop F/A vs. Coolant Temp vs. MAP table in that range?
    Free HP Tuners Beginners Tuning Guide
    LS1 Tuning Guide
    Michigan Snowmobiler
    1969 Firebird: 11.67@114 [email protected] 1/8 1.70 60 ft. EPS cam 234/246 .602.606 114+3, 6.0 LQ4, L92 heads milled 10.5:1, Ported L76 intake, ported 90mm Holley TB, 100mm MAF, FIC Custom injectors, Hooker LT, PYPES dual exhaust with an X pipe, 4L65e with all of the good parts inside, FTI 4000 RPM Stall, 12 bolt with 3.73 gears. HP Tuner tuned by me
    Mar 2010
    Texas Hill Country
    3,299
    I have it set to 1.0 for all values 140-220 ECT (approx). Am I supposed to change that back to stock settings after tuning MAF/VE? Won't that mess up my PE? Also, at what temp does it go to CL? Is it not 93 degrees (in the CL enable table)?
    Advanced Tuner printmanjackson's Avatar
    Nov 2009
    USA
    412
    I have this same problem. is this something the throttle cracker can fix?
    Mar 2010
    Texas Hill Country
    3,299
    printman, mine only went away after I went speed density. i could never get my maf table right with my cam, or whatever was giving it fits. car is running, idling great now. good luck!
    Nov 2009
    USA
    412
    thanks, I'll try that but I didn't think the MAF affected idle.
    did you put the Open Loop F/A vs. Coolant Temp vs. MAP back to the original settings or leave it at 1
    Senior Tuner S2H's Avatar
    Apr 2005
    4,387
    throttle follower and cracker are not used at idle...
    follower is used when you have your foot on the gas pedal, cracker is used primarily when your foot is off the gas pedal...but is present when your foot is on the gas pedal
    neither is used when the clutch is pressed in or when you are in "coast down" mode
    cracker is best used to give you some cusion air when shifting to allow the rpm to fall at a controlled rate that will best match your shifting patterns to get it in the right rpm range for your upshift
    you can remove or add air to it to control bucking when you let off the gas as well
    follower is useful in when taking off from a stand still
    you can add air or take away air from it to stop low throttle bucking
    as soon as you push in the clutch, or go to coast down, they both decay to 0
    if they dont reach 0, you dont enter idle and your adaptive idle parameters cant do their job.
    typical reasons for your cold idle issues are usually not enough airflow at idle or improper Air Fuel Mixtures..
    with a wideband, you can check A/F and you can adjust your OLFA(open loop Fuel air.coolant temp vs MAP) table so that your Air Fuel is close to stoic at those colder ECT's.
    getting fuel correct is more important than having a correct RAF because RAF will learn and open loop fueling will not.
    -Scott -
    Apr 2005
    4,387
    Quote Originally Posted by printmanjackson View Post
    MAF and VE values can affect idle...though it is mostly VE at idle unless your OS is 100% MAF
    it typically is a blend and is controled by settings on the dynamic airflow tab
    -Scott -
    After about two months of tinkering with the MAF and VE I have finally moved on to the Idle. I got my RAF close enough to where the STIT are under .5g/s off. Now my question is how does one get the PCM to catch properly. The car likes to die or nearly die as I push the clutch in and pull up to a light. It will do it if I rev the engine as well but not as bad.
    Nov 2009
    USA
    412
    Quote Originally Posted by soundengineer View Post
    is there a better way to tune other that using a WB? I have noticed my WB is not very accurate until the engine rune for a while. I don't think that will work well on a cold start.
    Apr 2005
    4,387
    buy a better wideband...
    how do you know its not very accurate...what are you comparing it against?
    you cant compare it against the narrowbands sensors that rely on exhaust heat to work properly...
    when I do OLFA.. I usually temprorarily set the udle up to 1200~1500 ish in the tune so that I dont get the cam overlap short circuiting the Air fuel like it usualy does at idle...
    gets you a more accurate reading for a cold start warm up to full temps.
    then after I am done with OLFA, I set it back to my preferred idle settings
    remember..you cant use AFR error for OLFA.. you have to make a custom PID for "Stoic Error"
    -Scott -
    Senior Tuner Frost's Avatar
    Jan 2006
    Richmond VA
    1,950
    This isn't absolute though.. it is for some cars and OS's but certainly not all.
    Many years of the F-body for instance, the throttle cracker IS active at clutch-in or off throttle for autos. I don't think I have ever seen a six speed vette though that the TC is active during clutch-in.
    Steve Williams
    TunedbyFrost.com
    Apr 2005
    4,387
    Quote Originally Posted by Frost View Post
    I've owned 3 fbodys... 99/00/01...and have never seen cracker when clutch gets pressed in...
    as soon as you press in the clutch it decays to 0
    unfortunately we dont have a table for decay time on the cracker, but we do for the follower
    cant say 100% for certain on the auto's
    but typically it decays to 0 when your torque converter unlocks for coastdown...
    -Scott -
    Jan 2006
    Richmond VA
    1,950
    I'm just relating experience. Seeing a few dozen cars doesn't mean you've seen it all.
    Steve Williams
    TunedbyFrost.com
    I just got done toying with my cracker and follower. With changes to the follower I got noticeably better response and power starting out from a stop. Whereas with additional cracker on a H/C/I setup it kept the car from stalling after a WOT run when going to clutch in. As well as from a start up to say 5-10 MPH and then going 0% TPS and clutch in the car would die. Again cracker fixed this. I did not mess with decay at all but need to a tad.
    Tuning Addict WS6FirebirdTA00's Avatar
    Jan 2005
    Concord, NC
    8,093
    Agreed. My car does not zero throttle cracker with the clutch pushed in.
    Sulski Performance Tuning
    Jan 2006
    Richmond VA
    1,950
    This underscores one of the largest problems with online tuning discussions.
    Lots of people are familiar with THEIR car and THEIR calibration and it's OS, and they forget that going + or - one year means that the answer is not always the same. This is particularly true for the airflow adders such as these, but stretches out much further.
    Steve Williams
    TunedbyFrost.com
    Nov 2009
    USA
    412
    so what is the proper way to go about tunning and adjusting the throttle cracker and follower? I have built histograms for each and have logged data but what and how do you use this information?
    the problems I have are falling idle sometimes and will not idle with AC on
    For the AC you need to look at the Adaptive Idle Airflow and add some air under the A/C on part. As for the Craker it was all trial and error for me. Can't give it too much or it will never come down and too little and it will still stall. Overall I ONLY needed to mess with the 400-2200RPM by 0-40 MPH to fix stalling at a light or maneuvering while parking. Follower was the same way. Just trial by error. Add more air if needed in fairly small increments until you get the desired results.
    This is how I did it and probably not the right way but it did work for me. The car is still hard to start when heat soaked and will die easily due to the intake air temp not reading the right temp. Only thing wrong with the tune left that I can find. I guess i'll have to do the bias table. /sigh
    Jan 2006
    Richmond VA
    1,950
    Quote Originally Posted by Exidous View Post
    No just move your IAT out of the engine compartment so that it doesn't heat soak.
    Steve Williams
    TunedbyFrost.com
