Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 93
Thread: Idle, Throttle Follower, and Throttle Cracker
  1. #41
    Advanced Tuner printmanjackson's Avatar
    Nov 2009
    USA
    412
    Quote Originally Posted by 79 z28 View Post
    Not sure but I might have a few issue working at the same time on this idle hang.
    It might be physical as well, I need to check out the cruise control servo and throttle cable and stuff. It seems like there are a few chararcteritsics to it when it hangs. If I blip the thtottle I can get it to come down off of one level of the hang up and then its at the 1500 rpm hang for about 5 seconds then it drops to normal idle.
    is your idle hanging while the car is still or is it hanging while rolling? If it's hanging while rolling, is the clutch in or out?
    '02 Corvette
    LS6, MN6, LT's/X pipe and TI's, Honker CAI, AI 243 heads, PatG Custom Cam, FAST 102, LS2 TB, Red Top inj, HPTuners & NGK/AFX
  2. #42
    May 2010
    250
    All of the above. It seems to hange if I dont push the clutch in all the way while I'm shifting. It hangs while I'm rolling to a stop with the throttle at 0%.
    really need to figure out the problem individually I think.. specialy the physical cable and cc unit.
    anyway to get rid of the cruise control system, it doesn't work anyway
    included my tune file and scan file. First part of the scan is a WOT run in 2nd gear. Rest of it is normal driving
  3. #43
    Nov 2009
    USA
    412
    so it does NOT hang with the clutch pushed in?
    if you're rolling to a stop, do you have the clutch pushed all the way in when it's hanging? or do you put it in netural and coast when the idle hangs?
    it's important to understand exactly when it's hanging. hanging idle is usually too much air and stalling is not enough. it could be in the RAF, TC or TF.
    hope this helps
    can't open your file, you must be using the new beta version.
    '02 Corvette
  4. #44
    Senior Tuner Frost's Avatar
    Jan 2006
    Richmond VA
    1,950
    No mystery here; you need to do idle airflow tuning. I seriously doubt you need 13.5g at hot idle. That's right out of your idle airflow table.
    Steve Williams
    TunedbyFrost.com
  5. #45
    May 2010
    250
    two levels of the hang.
    dont push clutch all the way to foor and it hangs at what ever rpm your at this is while up shifting and down shifting
    when you get by that hang then it hangs at 1500 rpms while the car is rolling to a stop clutch in working through the gears or if your crusing at what ever speed and push in the clutch it was hang 1500 before going to idle..
    I adjusted the base running airflow table already and it helped with things buy though is I need to adjust the throttle follower decay delay?
    the ve needs work as well, the car certainly isnt dialed in yet
  6. #46
    May 2010
    250
    Quote Originally Posted by Frost View Post
    Sorry Frost you got in before I finished typing.
    whats should those values normally be?
  7. #47
    Jan 2006
    Richmond VA
    1,950
    I have no idea; I haven't logged your car.... what does it WANT for those values? Likely almost half of that...
    Steve Williams
    TunedbyFrost.com
  8. #48
    May 2010
    250
    OK. I did a little ajdusting to that table but need to do some more then how does that table control things? By adding air or fuel or does adding air add fuel by function/default of the rest ?
    *********** Sorry for that last questions.. duh.. just need to read the table explanation when you highlight it.... new toy.. sorry
  9. #49
    Nov 2009
    USA
    412
    set up a histo for desired idle airflow, that should get you closer than just guessing
    '02 Corvette
  10. #50
    May 2010
    250
    idle cracker airflow and idle desired airlfow are both in red so its an unsupporetd perameter, how do I make a histo to track it then?
  11. #51
    Nov 2009
    USA
    412
    make sure the PID in your primary table?
    '02 Corvette
  12. #52
    May 2010
    250
    I'm using custom os and 2.23, not sure if this has anyhing to do with i?
  13. #53
    May 2010
    250
    Question... should I wait to mess with the main ve table until I get the idle airflow table perfect?
  14. #54
    Nov 2009
    USA
    412
    I would tune ve first, then idle tune, then maf
    '02 Corvette
  15. #55
    Tuning Addict WS6FirebirdTA00's Avatar
    Jan 2005
    Concord, NC
    8,093
    If you do it that way you will need to revisit the idle again after MAF changes
    Sulski Performance Tuning
  16. #56
    May 2010
    250
    getting a few things worked out or at least know what the issues are.
    The throttle cable does have issues coming from the servo but its hang is easy to realize. Need to get rid of the cruise control altogether as it doesn't work anyway and run a new cable to fix that issue.. not going to drop big money on a new servo if they even make one.
    the idle airflow table is where I am doing the work .. looking at ect and making adjustments from there... my target stoich is 14.4... we have 10% alc in the gas out here.
    WOT seems to be the easiest to tune for so I am not even doing it right now, all my work is at 1200-2000 rpms.
    I need to go back through the injector tables and make sure they are setup correctly, I did not build this tune, it was paid for.
  17. #57
    Jan 2006
    Richmond VA
    1,950
    Idle airflow and fuel mixture are separate entities.
    Steve Williams
    TunedbyFrost.com
  18. #58
    May 2010
    250
    At what point does the computer tell it to use the VE table?
    thx for all your help Frost
  19. #59
    Mar 2010
    Texas Hill Country
    3,299
    That's adjusted in the Dynamic Airflow tab.
    Search for, download and run the RussK idle config. That will set your RAF. Make sure your MAF and VE are tuned first.
  20. #60
    May 2010
    250
    Well its already in SD right now. I do have a histo that shows idle airflow- desired airflow that came with 2.23 and the 1 bar custom os. Is that telling me what I need to know?
    It seems to coincide with what frost had said earlier about the values at 190* wanting to be half of what they are set at.
    I still have a damn throttle cable issue as well, its killing me.
