Hello all,
I have a 05 GTO with a Procharger. I installed it in OCT and it was tuned at that time. Ever since it got warm, my AC is running hot at idle. I first checked the freon, it's right at 1.8 lb where it should be. I have since noticed that the fans no longer seem to come on the high setting. I have spoken several times with my turner and he insists that they are set up properly. It looks to me that he has them set on a one fan system and he can see that the fans are running 100% on the TECh II. He also kept telling me that the fans are a pulse type and if set at 100% they are running at full blast.
Well according to my research, the fans run on a multistage three relay setup and as the temp rises, the number 2 and 3 relays switch and the system goes from sending 12v to both fans and then sends 12v to each fan. This effectivly doubles the speed of both fans. Am I correct? If so what should the fans settings look like so I can show him?
I am running a 160 stat and using the fans included with the Procharger kit.
Thanks in advance
The turner has HP I don't so screen shots please.
