Page 1 of 3 123 LastLast
Results 1 to 20 of 42
Thread: New to 2.0 user question thread
    Not sure if it will help condense it, but maybe a few "new to 2.0 user" questions can be answered in one thread. (I am sure you will be getting some)
    I know we can only save in .hpt form now. Are there any issues with going back and fourth with old tunes we already made? Should we open, then resave them immediately, or will 2.0 still allow us to write *.bins
    Senior Tuner S2H's Avatar
    Apr 2005
    4,387
    Re: New to 2.0 user question thread
    you will only be able to save in .hpt now
    there are no problems with opening an old .bin, making changes in 2.0 and saving it...it will just save in teh new .hpt format...and then you use th eflash section integrated into the VCM Editor(much better than the old flash)
    -Scott -
    May 2004
    4
    I can't figure out how to setup my LC1 W/B in the #6 ( or any other ) histogram table. It worked fine in 1.7, but I can't seem to make it work in 2.0 ? I've selected the LC1 PID in the "Plot value" and the "x header" and "y header" section but no go. I just get the following message
    This Histogram is not supported with the current loaded parameters.
    If this Histogram references Tables, it is possible that the vehicle
    you are connected to does not support these Tables. It is also possible
    that the sensor required for the Table is not found in the loaded
    parameters.
    If this Histogram references Sensors, it is possible that the sensor
    required is not found in the loaded parameters.
    If this Histogram references PIDs, it is possible that the PID required
    You will find all of your loaded parameters located on your Table Display.
    To add more parameters, right click the table display and click insert.
    For example, if you have a histogram built that maps Timing Advance
    and you do not have Timing Advance inserted on your Table Display,
    the Histogram will not function.
    Apr 2005
    4,387
    try one of my histogram config files....
    www.audiohelix.com/file
    under the histograms section...just try the VE Wideband AFR table and see if it helps..
    sounds to me like you have a simple configuration setup issue
    should look something like this
    dont mind my plot filtering...I tune in open loop and I use that PID filter to exclude any IDLE data
    the "X" and "Y" tables are for you to put in teh values that you need...like in the Primary ve table you need to plot X as RPM and Y as MAP(kpa)
    or as I ave shown in the example above...just select a tabel and its done for you
    version 2 here below is teh same thing only plotted as PID's instead of a table
    it is almost always smarter to use an existing table because it automatically puts the right values in the X/Y fields
    -Scott -
    Am I missing something (probably) or did we loose "lean cruise" with 2.0
    If so, what happens if Lean cruise was enabled under 1.6, but we start tuning with 2.0?
    2004 GTO M6, 403, Callies, compstar, wiseco, QTP HV oil pump, QTP 2 piece timing cover, EDC custom AFR 235's, LS6 intake, P1SC-1 Procharger maxed @ 13psi, 224/232 600/600 114 EDC custom cam, JBA shortie headers (thanks California) custom boost referenced return style fuel system with surge tank, walbro 255, staged magnafuel 4303, Dual LC-1, Dual Aeroforce Interceptor gages, Nexus fP and boost gages.
    Tuner kabbott's Avatar
    Sep 2004
    Ba co. Md
    121
    Engine>fuel control>COT,lean cruise
    2000 Impala 3.8
    4T65Ehd 3.29
    VCM ID:7DS739259ui
    VCM OS ID:9387047
    Quote Originally Posted by kabbott
    When I go there....All I get is COT enable / disable and some settings. nothing relating to lean cruise....
    Sep 2002
    Chicago, IL
    6,395
    you in the advanced view mode?
    We got this guy Not Sure, ...
    Quote Originally Posted by Keith@HPTuners
    That was it...Thanks Keith
    Apr 2005
    4,387
    its not enabled in US vehicles because it has a compare to and jump to if not equal command going on there..LOL
    I'm not saying anything else....just letting you know that It may have a table...but that doesnt mean that its going to work
    -Scott -
    Advanced Tuner xonelith's Avatar
    Oct 2004
    Whitby, Ontario, CANADA
    408
    Edit: Never mind the question I had here.... figured it out
    All Motor 2001 GA GT1
    Aug 2004
    UCSB-Chemical Engineering
    171
    did you put the pid in the [glow=red,2,300]table[/glow] and the histo
    Quote Originally Posted by Racehead
    parameters.
    98 Camaro, M6, HPTuners, heads and cam
    Quote Originally Posted by soundengineer
    Well that kinda stinks......
    I read somewhere someone was able to get this working?????
    Apr 2005
    4,387
    some of us know whats up
    but the EPA has *STRICT* Guidelines reguarding "lean Cruise"....
    -Scott -
    On an HP laptop running win98 I am getting an object file error when I open v2.0. I do have .net 1.1 installed already. Are there any other issues that I should look for? HPT v2.0 works sometimes and other times it locks up the computer. I'm assuming it is related to the error I get on startup.
    Sep 2002
    Chicago, IL
    6,395
    You need at least 98SE for 2.0
    I should have been more specific. It is win98SE. I would use one of my newer computers, but they lack a serial port.
    Sep 2002
    Chicago, IL
    6,395
    How fast is your laptop? How much memory?
    It's only a 433mhz processor, but I have 512mb ram.
    Nov 2004
    231
    what happened to the rpm stall value in the dfco tab. i cant seem to find it.
    I have v2.0.16 and 04 commodore support.
    ronny
    04 VY Commodore ute M6 ls1, 918 valve springs, TR6 plugs, genttrbb twin turbo kit, 60lb seimiens injectors, Bosh 044 fuel pump, SX fuel reg, PLX wideband,Full Castle Hill Exhaust with 2 1/2in dump pipes, 4in cats into twin 3in cat back (no merge), Ripshift, oz700 clutch and 3.73 diff gears
