So here's what I'm running into...
I dialed in the MAF curve with the stock injectors in preperation for the new deatsch werks 65# injectors.
These injectors flow 66.7 lbs/hr @ 43.5 psi which works out to 77.02 @ 58 psi.
Since I can't get the injector flow rate to go above 63.5 lbs/hr I have tried to use both the IAT and Volt modifier with no luck. I have also screwed with the offset tables but not much luck there either.
The fuel trims are hangning around -15 which is no good.
Has anyone used these injectors before?
