Results 1 to 5 of 5
Thread: injector threshold
    Dec 2007
    47
    injector threshold
    I read on hp that one of the v8 guys reduced the injector threshold to gain some ecomony, first i got a v6 that has 6 different steps for o2 sensor rich/ lean threshold state cold,idle,decel,normal,accel, and wot, i using tiny tuner, what i did was lower the lean threshold for normal , which i assume is cruise, i can't see any change, does know the correct way or whatever opinion you may have on the subject. thanks
    Advanced Tuner passingpower's Avatar
    Aug 2008
    Grand Rapids, Michigan
    301
    This is what I'm using. I have picked up mileage with this.
    Fuel (91) -> Open Loop & Closed Loop -> O2 Sensor Rich/Lean Threshold
    mv Lean mv Rich
    State Cold 500 675
    Idle 375 425
    Decel 320 380
    Normal 300 400
    Aceel 500 650
    High 500 650
    [TinyTunerData]
    500,675
    375,425
    320,380
    300,400
    500,650
    500,650
    Dec 2007
    47
    injector threshold
    Thanks i'll try those settings
    Mar 2009
    8
    [TinyTunerData]
    500,675
    375,425
    320,380
    300,400
    500,650
    500,650
    I tried these settings and it started to miss fire (I have 60lb injectors and running E85) and set a lean o2 code. did you have to play with the settings to get them to work?
    Aug 2008
    301
    Nope. I set them and noticed an immediate difference in throttle response and a little later in mileage. No misfires at all.
