i bought a 2000 malibu cheap, it had a bad(but running) motor. i picked up a rolled 2004 montana for $300. i used the 3.4 out of the van and put it in the malibu. i could never get it to run right so i bought vcm suite. long story short both vehicles had a bad maf.
now that i have the engine sorted out i need help with the tranny.
first off i need an understanding of the tranny logic, it is really hard to tune something you have only know basic therory. eg there is no holding pressure table i know at least the computer dosent "divine" a holding pressure(my main issue) how does it come up with that. etc etc
the initial problem i have had is the tranny will slip at moderate throttle in 2nd and 3rd gear, the computer catches this and clamps down on pressure, about a second later it will slip again and repeats the cycle. second 1-2 shifts at wot are doggy and it bothers me that it will burn up clutches. if i lock the force motor to 500ma it don't slip and shifts very hard at light throttle and quite nicely at wot.
then i started by lowering the force motor amperage by 10% below 20psi and blended it in with the rest. this helped but shifts were still sluggish. i upped shift pressures by 15% for 1-2 and it shifted better. after some driving around the tranny started to chatter, but in 1st gear moderate throttle. i took a log and line pressure (%?) is at 9 when it does this(engine torque around 110 ft.lbs) shouldnt the line pressure be quit a bit higher than that. how does the computer come up with the holding pressures? please edumacate me here
