Results 1 to 9 of 9
Thread: E85 fuel economy
    Mar 2009
    8
    E85 fuel economy
    I just switched to E85 and my fuel economy went from 28 to 18. Has anybody done any tuning to get better economy with E85?
    Nov 2009
    16
    The expected economy would be about 20 if you were getting 28 before. The extra power is probably just making you put your foot down a bit more than usual lol.
    Mar 2008
    45
    You can try bumping up timing in the areas that you cruise around in. You can add quite a bit with e85 and that will help some. Its inevitable that you will lose fuel economy when using e85 because it requires ~30% more fuel than gasoline.
    Dec 2005
    Sydney Australia
    510
    in my recient testing there seems to be around 27% difference between ULP and E85
    Mar 2009
    8
    I've been playing with adding a few degrees of timing and it seems to run a little better, I don't know yet if it helps economy I will have to fill it up and check mileage.
    You can lower the compression of the engine as well to bump up the fuel economy and bring back the spark to a more reasonable level. I've seen some Grand Prix guys max timing out in cruising at 50* with no KR.
    Shave the heads a bit and dial back the timing to the 40's and it will increase power and economy. If you get the combination of compression, spark, and tune right you can actually gain a couple MPG over stock.
    Yeah it is expensive and hard work but - HEY - You're running E85!
    HAI, 180* T-stat, Autolite 104's, NorthStar, Gen V, 1.8 SLP Rockers, SLP Ported Headers, Custom 3" Downpipe w/high flo cat, Dynomax Catback Exhaust, DHP PCM, Fuzzy Dice Mod.
    Jan 2009
    29
    Running lean cruise helps a bunch.
    Dec 2008
    Old Orchard Beach Maine
    915
    Quote Originally Posted by darkhorizon View Post
    dont think you can discuss lean cruise on here since it increases NOX emmisions
    PB's 1/4 mi 12.21 117.75 trap ,1/8 mi. 7.779 93.99trap , 1.949 short time (FWD W body)
    Senior Tuner S2H's Avatar
    Apr 2005
    Schexnayder Racing - Arnaudville LA
    4,387
    basically you need to know that with e85, you will have approximately 30%~40% less fuel economy...simply based on the fact that it takes 30%~40% more fuel to achieve the same stoich value..
    -Scott -
