Page 3 of 3 FirstFirst 123
Results 41 to 48 of 48
Thread: Russ k's adaptive idle config.
  1. #41
    Sep 2017
    3
    Hey Russ K I'm trying to find the info on the GenIII but cant find it is there anyway you can send to me. Thanks in advance
  2. #42
    Sep 2020
    4
    Hello sir, could you possibly send me the attachment. For whatever reason its not clickable on my end
  3. #43
    Jan 2007
    34
    Quote Originally Posted by HEATHPATRICK0 View Post
    https://forum.hptuners.com/showthrea...l=1#post659192
  4. #44
    Potential Tuner 427troy's Avatar
    Jul 2023
    Oregon
    3
    Anyone still here?? What software do I open that .cfg file with? VCM Scanner and VCM editor both don't want to open it. My car wont idle until it is doing less than 5 mph. six speed manual, and when I push the clutch in it stumbles with a hunting idle until the coasting car slows below 5mph. Then it suddenly is all better.
  5. #45
    Jan 2015
    Arizona
    452
    Quote Originally Posted by 427troy View Post
    Anyone still here?? What software do I open that .cfg file with? .
    start here https://forum.hptuners.com/showthrea...dCDR6D7t30xBWA
  6. #46
    Jan 2023
    1
    how do you transfer this to vcm
  7. #47
    May 2022
    locust grove, ok
    14
    The issue is not wanting to start without pedaling but after starting it runs fine. It?s a square body swap with a 6.0LQ4,102 Holley TB, TBSS intake, 60LB injectors sloppy stage 2 camshaft, 243 heads, long tubes and 10.2 compression. I?m hoping to get past this issue before I start any ve or maf tuning. I have set the idle airflow and set the idle advance to 23^ and set the same in the base tables. I?m using a p01 pcm. Thankyou in advance
  8. #48
    Nov 2023
    1
    Quote Originally Posted by Tuffy282000 View Post
    Did you ever get through this?
