ok i use a custum pid with new beta scan but no result on my chart or primery table ....help
Code:
Lambda to AFR custom PID
Name: Lambda to AFR
Abbrv: WB AFR
Sensor: none selected
Units: :1
Function: [PID.6160] * 14.68k
Code:
Name: Lambda to AFR
Abbrv: WB AFR
Units: :1
If pid 6160 is named WB Lambda B1 then it should work, not sure why you have a k at the end there.
Did you add the custom PID to the table? You have to do that first after you created it. It won't log without it in the table.
I think you might need the = sign in front of the formula? Not where I can look at my custom PID's right now.
Post your config.
