Results 1 to 8 of 8
Thread: another cool 2.0 feature...exporting tables
    Senior Tuner S2H's Avatar
    Apr 2005
    4,387
    So I found another cool 2.0 feature that will most likely be very useful to many "e-mail tunning helpers"
    Say Joe Schmo needs a little help...
    he's just bought HPTuners...
    you have a Liscense for 00/01 camaro's/birds
    he has liscense for 99/02.....and he needs help on his 99
    well..he can send you his bin...and his logs....
    you can open his bin...but you cant save yoru work cause you dont have a liscense for his 99.....
    hmmmm...
    well...
    do your work..and export the data
    send him the txt file and he can open it...and directly copy and paste it into the appropriate table....
    so now you can help newbies learn what they are doing even if you dont have a liscense for that particular vehicle...
    just have him/her send you their new bin every time..or reload the tables yorself the same way..
    I just helped out a fellow f-body with a problem cause he didnt know what to look for or what to change...
    he sent me a bin and about 4 diferent logs....
    I looked at everything and sent him the changes in a txt file...
    he copied...pasted...and now his minor issues are fixed
    -Scott -
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,265
    Re: another cool 2.0 feature...exporting tables
    yah theres alot of neat stuff...ive had it for 3 weeks & every day i find something new in it...so much new stuff throw in there to get used to.
    Apr 2005
    4,387
    I just built Red Supra's worksheet in teh scanner..
    MAF hz Table and Dynamic Airflow PID.....
    [PID.2320.IMP]*7.57575 and in lb/min
    no need for a 4 page excel sheet anymore
    and I built my LTFT+STFT MAF as well...
    [SENS.114]+[SENS.116] in %
    so much faster now
    -Scott -
    HP Tuners Support
    (foff667)
    28,265
    I'll have tot check thata out
    HP Tuners Support
    (foff667)
    28,265
    Quote Originally Posted by soundengineer
    so much faster now
    why not make up a histogram just plotting afr error against the maf output frequency table? wouldnt that do about the same? Or am I missing something?
    Apr 2005
    4,387
    normally I do use MAF AFR Error %
    but for those without a wideband...or for those that wish to get it close while doing the VE table..RedHardSupra's excel spreadsheet is a good starting point...and you can log that data while doing VE and get a really close starting point on recalibrating the MAF..not perfect..but close, and then atleat it will be within only a few % wen you do the AFR with Wideband
    -Scott -
    Aug 2004
    UCSB-Chemical Engineering
    171
    thanks a bunch scott. as soon as i get a break from college i will throw those tables in. you have been very helpful. i wish there were more people on these boards like you. i will pass on anything that i learn to help others out so your info doesnt go to waste. thanks
    jon
    98 Camaro, M6, HPTuners, heads and cam
    Apr 2005
    4,387
    I wasnt referring to you on the person I fixed...but I am hoping to be your fix as I think we can nail your problem too...
    -Scott -
