why do the 6l80e's somtimes develope a flare shift after a re-program,, even just a minor change in shift speed or wot change will cause a light throttle flare shift only in D mode,,
2 L99 camaro's
one had a flare 2-3 shift only in D with light throttle (fine in sport mode) , did a tech2 fast re-learn, didnt fix it,, finally left the batt disconnected over night and it was fixed
the other car has a flare on the 4-5 shift (didnt change any of the 4-5 shift parameters), did the tech 2 fast re-learn, disconnected batt over night , still there , only in D(sport mode is fine)
is there some other re-learn/ reset that needs to be done after a flash to get the adapts learned or whaterver is causing the flare shifts
