Page 5 of 5 FirstFirst 12345
Results 81 to 85 of 85
Thread: 2.22 with net framework checks removed
  1. #81
    Tuner RedWS6 00's Avatar
    Mar 2006
    Hampshire, England, UK
    66
    I've got the same issue. I was going to try the install on the first page, but the link is no longer there. I have removed .NET framework 4, and tried to install nd still get the .NET 2 error so I'm still struggling with this.
    EDIT just found a very good link. Solved it:- http://www.performancetrucks.net/for...nstall-466156/
    had to download Orca so I could edit the MSI.
    2000 Red TA WS6 M6 in England, UK
    Patriot Stg.II Heads & 226/226-112 0.585/0.585 Cam. Corsa Cat back, F.A.S.T LSX Intake / F.A.S.T Fuel rails, Dynatech LT's/Y, Wisper Lid, ported MAF, 52lb/hr. 160 stat. !AIR, !EGR. Walbro 255, SPEC Stage II.
    HPTuners 1BAR SD Tune. Wide Band AFR.
    389RWHP/380RWTQ ([477HP/460TQ]Flywheel) Dyno Dynamics
    Photos at:- http://www.solent-renegades.co.uk/ca...00trans-am.asp
  2. #82
    Sep 2002
    Chicago, IL
    6,395
    Sorry for the troubles.
    You can download 2.24 direct from your customer page. It will solve the issues you're seeing.
    We got this guy Not Sure, ...
  3. #83
    Dec 2009
    Maryland
    Not sure if I am in the right place or not, please direct me if I am wrong.
    I was running HPT 2.23 beta on Windows 7 and it worked fine. Updated to Windows 8 a while back. Had not tried HPT for a while. When I tried to start the scanner I got the same error that has been posted (Couldn't find library MSVCR80.dll)
    I then decided to be smart and reinstall it. While trying to Install I get the net 2 framework error. And I cannot install net 2 in windows 8. I do have version 2.24 downloaded. I am going to try install that but is there anything else I need to do first?
    Thanks,
    John
  4. #84
    Sep 2002
    Chicago, IL
    6,395
    2.24 uses .net 4 and should install onto windows 8 without any issues.
  5. #85
    Sep 2002
    Chicago, IL
    6,395
    I'm locking this thread.
    2.24 has been released with .net 4 and is available on the customer login page. This resolves any installation issues all the way up to Windows 8 x64.
