Hi
I read in this forum that your scanner will support ISO-Protocols soon. Since that thread is a bit older, I wonder if this protocol is already supported in the latest beta? If not, when will it be available?
Thanks,
Mat
Hi
Thanks,
Mat
'97 Jeep Grand Cherokee ZJ, 5.2L (Canada Import), 2" Lift
(CAI, Modded Kegger, Ported TB, 3" Cat-Back, SCT Custom Tune)
'98 Jeep Grand Cherokee Limited ZG, 5.9 V8, Stock
'03 Skoda Fabia, 1.4L 16v
'98 Chevrolet Camaro V6, 3.8L, Targa, ZZP GT1 Cam, Dynomax Cat-Back [sold]
Not supported yet(requires a firmware update that we are working on).
Same time Dodge software is released as the firmware should be in the same build(dodge's require a firmware update)
OK, I understand.
When do you expect it to become public beta?
Looking forward to this. ISO support should allow me to scan my OBDII ('96) BMW. That'd be quite handy.
1988 Mazda RX7 TII - Forged 347" LS1/2004r/3600 stall/Stage III Heads/Cheatr Cam/Precision 76GTS/E85/HP Tuners 3 BAR OS
Yeah, my E36 is definitely OBDII.
Is the ISO protocol supported in the latest beta?
I don't think so, give it a shot if you already have access to it.
Doesn't work...
A small window appears for a split second (to quick to read something). After a couple of seconds, it tells me that the ECM couldn't be found. One time it could connect but it wasn't possible to read any data.
I suppose that there's no ETA for ISO support. Right?
BTW. Is there an ETA for JTEC read support?
- Mat
Its a low priority right now-ISO that is.
No eta on JTEC read support at this time.
