its weird as mine is doing the same think as yours isaak and i loaded up the exact same bin file as i had and the car ran perfect on. Im very confused now.
might try the 2.22 version just to see.
96 l67 CAVALIER. PT76GTQ TURBO AND IC. PB: 10.62@138MPH ON 19PSI. DYNOED 502WHP AND 415FTLBS OF TORQUE.
E-mail support and tell them what version of the beta you have not 2.23 but 2.23.xxx and ask for the newest version and possibly a version of two back to verify if it is a software problem and not a tune/pcm issue.
Link to this thread when doing it.
I am using version 2.22.3042.38626
As far as I know it is the latest... Steve, swap it over and see what happens!
ok my car exhibbited the same symptoms. i found cyl 1-2 plugs were faulty. they looked fine but the core was cracked in both. they were 550miles new. no more issure after changing them. issak checked his plugs and found them to all be ok
http://www2.turbov6camaro.com:443/maf.htm
Did some reading up on this, perhaps the maf delta is what is cutting off the power at 4500?
