Hey Guys,
This is my first posting, and thanks in advance for your help on this.
I just had my old 4.10 geared 10 bolt rear end swapped for a 3.91 geared 12 bolt. My tuner made an educated guess on speedometer recalibration. His guess resulted in a speedo that reads an indicated 60 mph at an actual 64 mph. I'd like to get it closer. I thought the speedo was accurate before the swap, but in retrospect, who knows?
In the Speedometer window of VCM Editor I see my tuner changed the original Tire/Gear from 5.95 to 6.24, the General VSS Pulses per Mile from 57648 to 54968, Final Drive Ratio from 965.2734 to 920.3906, while keeping Rev-Trans at 17.000. The original numbers were apparently installed on my computer by a speedo recalibration by a Hypertech Power Programmer when I changed my gears from stock 3.42 to 4.10 about 6 years ago. My tuner apparently adjusted those numbers by the ratio of 4.10/3.91 which equals a 4.859% difference.
I have seen postings in this forum that describe how to calculate VSS Pulses, and I calculate 52366. I'd guess the Tire/Gear is the ratio between tire diameter (25.6 inches for me) and rear end gears, which I calculate to be 6.547. I was unable to find a posting on how to calculate the Final Drive Ratio.
Here are my questions......
1. Was my tuner correct in modifying these three entries? If not, which entries should be modified?
2. Are my tuner's entries correct or are mine better?
3. If you like my calculations better, and the Final Drive Ratio must be changed, what are the steps to calculate this entry?
Thanks so much for your help!!
