Let us know what you've done, what works, what doesn't etc.
I just flashed mine for the first time, I moved PE to 50% throttle across the board, except for 0 and 800rpm (no point there), adjusted my TCC apply speeds, and PE AFR ratios (I just cut and pasted the 2400rpm line to 1600, 3200 to 2400, and so on, so that 4200 and up are the same).
It makes a noticeable difference. Oh yeah, and put the torque management retard to 0 through 50%.
Now, I need to play with the timing, so, any ideas are welcome. John
