Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
Thread: OK guys, start posting.....
  1. #21
    Apr 2004
    13
    Re: OK guys, start posting.....
    John, could I see a copy of your PE/RPM/TIME table before you added the -3.999 to it? I'm very interested to see if your changes are similar to mine as I have seen a very noticeable difference in acceleration.
  2. #22
    Great post John. I do have something for you.
    I'm trying to fix my shift points to 6K and I used a calculator to get the mph at that speed with my tires and gears. After I fixed my speedo for gears, my car is short shifting. I guess the trans tables didn't scale exactly how they should have. So here are the mph I got that I should be shifting at to be shifting at 6K.
    6000 36 69 112
    My values now:
    6000 35 64 90
    So do I just change the 100% throttle cells or should I also scale the lower ones a tiny bit higher.
    This was from the Shift speed vs %TPS vs Shift - Normal table. Do I change Hot and Performance also to match the Normal?
    2nd question
    Those other WOT tables look like this:
    1-2 33
    2-3 62
    3-4 90
    1-2 5700
    2-3 5500
    3-4 1000
    Do I change the mph in the first one to match the shift points mph? And same for the RPM, do I put 6K in all of them?
  3. #23
    Ok, I guess the WOT table has to match the 100% TPS on the partial throttle and it should shift at that mph. Mine were mismatched so it still used the lower WOT table values. Hopefully I can flash tomorrow and check.
  4. #24
    Dom,
    Yeah, you want to make sure that your WOT throttle shift points and 100% TPS shift points match up....to be honest, I don't knwo what takes precedence, the WOT Shift Point (I'd imagine this porbably does), or the value at 100% TPS.
    In any case, I've been matching my Normal, Hot, and Performance tables to each other, because I don't want the PCM shifting around between strategies. Just my preference.
    Pilotlie, I've actually dropped my PE AFR Adder tables back a bit. The car was sucking down gas like a pig, and it actually behaves a little better with the AFR a little lower (I still haven't been able to do much with the timing, though, so I may be able to fateen it back up later).
    Anyhow, I have to run right now, but I -3.299 as my max value right now........I'll try and get you a copy of the table this weekend, or next week...
    Talk to you guys then. John
  5. #25
    WOT table takes precedence for sure. Only after I changed those values it moved my shift points up.
  6. #26
    the v8 code has a seperate CAT protection routine, the V6 doesn't. That may give you an idea why....
    I count sheep in hex...
Similar Threads
  1. Changed Cam, Hard to Start
    By Blue-Z in forum GM V8 Tuning - Engine, Gas (Gen 3)
    Last Post: 09-27-2007, 06:10 PM
  2. Where to start tuning
    By 00GTP in forum GM V6 Tuning - Engine
    Last Post: 07-14-2006, 12:20 AM
  3. what would cause my car not to start?
    By WS6FirebirdTA00 in forum GM V8 Tuning - Engine, Gas (Gen 3)
    Last Post: 11-20-2005, 10:56 PM
  4. start scanning = record scanning ??
    By 2000Firehawk in forum VCM Scanner
    Last Post: 01-27-2005, 02:27 AM
