How I could see the AFR when I datalog in VCMscanner on LNF cars?
I see lambda, but I prefer AFR
thanks
thanks
Make a custom PID.
Lambda * 14.7 = AFR
That's for gasoline, E10 that most metro areas have would be 14.3ish.
'12 Camaro T3 2SS/RS LS3 M6, SLP TVS 2300, Flex Fuel
Do you know which PID number I need to used, because I tried about 4-5 of them, and didn't work
Under Oxygen sensors select WB Lambda B1
[PID.6160] * 14.7
You have to add it to the table and make a user defined PID for it to work.
