So this is going to be a big project and I need to ask everyone out there what would be the best way to go.
This is a 2007 Chevrolet Silverado Crew Crab 4X4. Originally it came with an L76. It had an MP1900 Magnacharger with a 2.8" pulley, 42# injectors, and ported heads.
What's on order now is a 6.2 shortblock with Scat 6.125 rods and dished pistons for Supercharger with blower rings. High Volume, High pressure oil pump, and special high performance main and cam bearings. Also the ARP bolts and all necessary gaskets.
The 6.0 block has the tricked L76/L92 heads, with .650 rated springs. I'm taking all the good parts off the 6.0 and installing on to the 6.2. Now...
I need recommendations on the perfect cam for the LS3/427 stroker I will soon have. I want one with a radical lope and something that I can pull roughly 1100 LBS with at 2000 RPM, TCC locked up, and not overheat. And when I stomp on it, pull the front tires off the ground. Also I need something reliable. I'm running roughly 8-9LBS of boost with these heads and at my elevation of 3400 feet. So people, I need your help!
Also I have my own HP tuners so tuning any cam to work is no problem.
Thanks,
Robbie
