Im running a 2001 GT with a zzp m90 kit Intercooled headered 3.4 pulley setup. I just installed a Throttle body from a GTP. Did 3 WOT pulls. Hit under 1 degree of KR but noticed the maf hz was way low. I was told I need a 2001 GTP maf table. I found a seni stock one in the repository. Do I just save the maf table from the 01GTP and pull open my current maf tune and click open file and load in the 01GTP file? then make adjustments as needed? Is it that easy? BTW Im using all of my sensors in the GTP TB
