ls1 01 camaro engine swap
tsp prc stage2.5 5.3l heads
tsp 228r (228/228) 114 lsa
fast 92mm
bluemaxx tb
42# @ 43.5 psi delphi injectors
had a 100 wetshot, but that's been removed
The problem is basically that on cold start the engine starts up fine and then the rpm drops until it dies (sometimes it recovers and is able to idle). You can see this happening in the attached log when I start it the first time. The second time I crank it the rpms drop, but it's able to recover until I shut it down.
First off, I don't have a wideband installed yet. That might be enough reason to tell me to go away, but I figured it's worth trying to get help with this cold start problem to help me learn a little about hptuners and ls tuning. I bought the car and with the engine already swapped in and the attached tune. From the reading I've done on this forum, the tune should just be completely redone with a proper OFLA table, closed loop, better idle speed table, a proper air mass (VE) table, etc. I'm working on getting exhaust redone for better ground clearance so I can road race the car and don't want to retune it before that.
The things I see in the log that might be the cause:
- Lean NB O2 values on startup. Maybe this in an artifact of just starting and these should be ignored.
- Low timing advance when the car is started for the first time.
- No change to RAF under 133 ECT... I saw this in the tune.
My cfg is the default which is most likely missing idle related things. Should I grab the idle.cfg in the sticky and get that data tomorrow morning?
Is it a waste of time figuring this out with this tune or without a wideband installed?
