Results 1 to 6 of 6
Thread: Commanded AFR leaning out in PE
    Tuner in Training skalor's Avatar
    Nov 2002
    Lehigh Valley, PA
    33
    I've been tuning my friend's turbo 4.8 2010 Silverado and I've come across something weird that I can't figure out. Sometimes while in PE the commanded AFR will go from the 11.29 that I'm commanding via the PE EQ table to a 12.24. It happens at frame 15,500 in the attached log. I'm thinking it must be time related because it only seems to do it on longer runs. Right now I have the AFR spark table set to start taking timing out a 11.7 so that when it goes lean it doesn't see knock but I want to correct this so I can up the timing again without having to worry about it.
    '89 Olds Cutlass Ciera International Coupe - '99 L67 minus the M90 plus a 60-1
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    Fuel Pressure? I think that it is reaching the limits of the fuel system. Is the boost spiking in that area? I would max out the fuel pump since your DC max is at 90%
    Gray Ghost- The abomination. 2007 Chevrolet Silverado CCSB. 98mm turbo, nitrous, 428LSX, Rossler 80E with a brake. Finally finished. 23 psi, no numbers, Slow as hell.
    PBM G8- Aluminum 364, twin Precision 67/66 turbos, 6L90 trans swap, CTS-V/Vaporworx fuel system, slowly making progress.
    Dads 2011 CTS-V- Stock bottom end, stock heads, LS9 cam, pullies, ported blower, ported TB, D3 goodies, and lots of nitrous.
    618/618 motor
    906/862 spray
    Caterpillar 50 Forklift- Duramax swap
    Nov 2002
    Lehigh Valley, PA
    33
    IDC is only at like 63%(14 msec) so I don't think there's anything wrong with the fuel system. It has 80 lb injectors and dual 255s in tank for reference. Besides, if it was the fuel system I would think it would still maintain the same commanded AFR. What happens is that the commanded AFR actually leans out to a 12.24.
    Aug 2010
    Roswell, N.M.
    1,956
    Wow never mind that suggestion then :O let me check back through your tune. Could be a Commanded AFR error.... If I see nothing wrong I'll ask one of the Geniuses on this forum. for Geniuses.
    618/618 motor
    906/862 spray
    Nov 2002
    Lehigh Valley, PA
    33
    No one knows why the commanded AFR is changing while in PE?? Here's a screen cap of it happening. The commanded PE AFR is set to 11.29 from 3000 to 8000 rpm.
    it is most likely the LTFT Purge Reduction Factor, i can't remember if you set it to 1.0 or 0.0 across the board and it should fix it.
    I count sheep in hex...
