Results 1 to 12 of 12
Thread: 92 GMC Sierra LS1 swap
    Got this truck last week. Another shop did the swap and tune. When we got it, it had 100lb. of fuel pressure! Wouldn't run but we fixed that. Now the problems we have are speedo way off, won't idle down past 950rpm, and can't adjust afr. It goes rich to lean back to super rich. In the middle of WOT ltft's are kick in and duty cycle is droping. ANY HELP WOULD BE GREAT! The last shop had it for a year while the owner was in Iraq. Now he's back and would like to have it.
    Aug 2009
    21
    For the high idle maybe there is an air leek somewhere, or the throatle blade is opened too much by the adjustment screw. Check the IAC and it should be zero.
    Log is short, but one issue is that it goes to PE (open loop) when TPS goes high as it should for 1 sec only than go back to closed loop for 9 seconds whicle the TPS is at 100% which doesn't make sence.
    97 Camaro SS, L98 motor, T56, 99 PCM and harness, Moser 12 bolt, BMR + Sphon suspension.
    07 300C SRT8
    Feb 2007
    San Antonio, TX
    1,255
    Call Allen Nelson @ 210-626-0278
    Janky Monkey Tuning
    Call or PM for tuning solutions.
    Cell 210-954-4985
    Wrench turning provided by 2 Tightwads Racing.
    Tune your own? Start here ----> Open Editor ---> Hit F1...READ!
    READ SOME MORE (Thank username 69Lt1bird): http://ls1tuningguide.com/
    Still lost? Consult a Pro!
    www.thetuningschool.com
    www.calibratedsuccess.com
    www.tunedbyfrost.com
    Quote Originally Posted by Cantalope Kid View Post
    Who is this Allen Nelson (is he at a shop?) and are you sure he would be willing to help?
    Feb 2007
    San Antonio, TX
    1,255
    Wink
    Quote Originally Posted by P.O.D._dyno&tune View Post
    He is the truck god. He owns Nelson Performance in San Antonio,TX. Also owns www.ls1truck.com!
    Janky Monkey Tuning
    Cell 210-954-4985
    Feb 2007
    San Antonio, TX
    1,255
    List of modifications to vehicle?
    Janky Monkey Tuning
    Cell 210-954-4985
    Jan 2009
    Spokane, WA
    480
    What's up on the speedo page? Specifically general and tire.
    On the tire size page, it says your calculated tire size is 96.17", but it should be 26.91".
    On the general page, all of the VSS and pulses are way off, probably due to the above. Also it's set for a 17 pulse VSS, is that correct?
    No modifcations. The engine is out of a 01 vette. The other shop had an ecu flashed to a 99 camaro. The truck is an automatic but it think the ecu is flashed for a manual. Don't know what kind of MAF(not a vette), it's a 3 wire. The original 4l60e was smoked so the owner put a 700r4 in it and it slips going into drive. What kind of trans would you all suggest?
    Quote Originally Posted by waynehartwig View Post
    It's not that bad, you can read "Tire Size, Current: 28" and "Calculated Tire: 96.17"
    A stock calibration is "Tire Size, Current: 24.94" "Calculated: 85.66"
    Actually I changed back to stock Tire Size to 24.94 and Gear Ratio to 3.42 and clicked on "Commit" for Auto Scale and all tranny tables went back to stock.
    I compared your calibration to a 1999 camaro/firebird stock file and I only found 47 differences (36 if you change back to stock tire size and gear ratio).
    Then I compared to a 2001 corvette stock and found 230 differences.
    ECUs might be the same but they are not controlling the same engine-transmission. I believe you need the original calibration for that engine and then check for normal operation.
    If the transmission is different that the stock one you’ll probably need a segment swap: in the same calibration file a tranny guru (check tranny section of this forum) replaces the transmission information for your particular hardware.
    Senior Tuner Google's Avatar
    Sep 2010
    Saint Peters, Missouri
    1,303
    The picture I posted shows your calibration details as a 1999 5.7L T56.
    #1. What year 700R4 are you using?
    #2. Are you using 28" tires?
    #3. Are you using 4.56:1 gears?
    Would not be hard to fix the speedo problem.
    Sep 2010
    1,303
    Problem #1, See pic.
