I have LT's on the car and I have the maf dialed in pretty close using a aem WB, now with the NB's and back to CL (cl enable set at 169 to get the NB's hot) and the LTFT's off and I know to re-set the fuel trims before every new scan, I have around 15 scans and most of the scans the nb's read good, avg. within 0-10 either way...close enough I think, but every now and then they start out of wack, one scan started pos 10-15 before taking several minutes to settle down and read good and one scan started neg 20-30 before taking about 10 minutes to settle down and read about 0...what is going on? Does the computer in the car get lost sometimes or is the HP readout off or something else happening? I want to put the car back to CL and be done with it, but is this a real problem? is going neg 30 on the STIT's going to damage the engine? Does anyone know how much fuel this is pulling? I need to know how to proceed.
