when Dodge/Chrysler is available for tuning , will you be able to Disable the VATS on HEMI 5.7L cars/trucks, cause the level of Anti-Theft system its at is similar to Mercedes-Benz.
The other day i needed to purchase for a 300C w/ a busted PCM in order to make it work "start" i needed to buy not only the PCM, but the Ignition Switch w/ the KEY FROM THE SAME CAR, surly a difficult situation and it took months, all due to Chrysler/Dodge PCMs not be Re-Programable so it can work with the busted PCMs KEY and Switch ,you can only UPDATE the darn busted or New PCM w/ a J2534 device, Lukily i found the Set of 3 parts at PAMs Auto Parts < Great by the way, and it started up great, so in other words only the Dealer has the power to do that.
AKA Anti Theft System on Dodge/Chrysler is a B#$@H
WE NEED VATS DISABLE
