http://www.dsxtuning.com
Just say no to bull s***.
I'm not sure but I would assume it's because those values are different for depending on the car. His instructions were for procedures on how to perform the task. He can't cover every car and every OS for each injector in his DVD. You follow his process and don't worry about the numbers in the video.
this is normal. didnt matter for me though. i was trying to get my 80's to idle using the supplied data in the dvd set. i think greg said he put this in as a bonus and it is a mathematical translation of oe data for us to use. unfortunately as has been stated some of it does'nt present so well.
i tried his data : the car was fat at idle. no ve control
i modified my short adder: better but still fat
i modded offset,min and def: ding ding ding i can now move around stoich with ve.
i think i am going to try creeping back up in short areas leaving 10% of control.
the video is a great guide to the concepts of tuning and i learned a fair amount. however theres no paste special section which has proved to be a real time saver. just my 2 cents and nothing substitutes good old fashioned trial and error on your own rig.
The 80s definitely want to idle rich. You have to idle the engine pretty high (900 or more) to get anything close to reliable control.
I think a number of you have mentioned it, but it bears repeating... The DVD outlines a process to follow to get the engine running better. In my process, we set the injector data (based on provided data) first, THEN we move on to solving for VE and MAF. If you have previously "baked in" errors to your MAF/VE, just swapping the injector data isn't going to fix it. There's a reason to my madness and I structured the training DVD to lead students down the right path, in the right order of events.
Again, please watch the actual DVD instead of just jumping into the raw data on the bonus disc. This exact situation is covered in the DVD, like this guy noted:
I hate to say "I told you so", but... Congrats on getting you car running better!
With that said, I'm working on finishing up DVD #2 now. This one will cover the scaling exercise, along with an interesting exercise to PROVE that it works as advertised. I'll also be tackling the Virtual VE system and showing how to use it with the stock OS (gasp!) to properly run a boosted engine.
1997 Trans Am WS6 - LS1 swap - TR224 - Pacesetter Longtubes - Yank SS3600
- 3.42 Moser 12 bolt - Wilwood Brakes - HP Tuners tuned - P1SC-1 Procharger
Have to say that Greg's instructions and data have worked very well for us Have set up several 600 - 800 rwhp projects utilizing 60's and 80's with little or no issues. Have setup an Excel worksheet for Scaling, VE Extrapolation etc. which makes the process a bit easier. Just finishing up a 2005 C6 (damn E40 ), 2 Bar SD, with close to 20 lb boost and it idles at 875 and we can move the fueling about via VE if need be. Will admit the C5's are a bit more work, but where there is a will, there is a way.
Thanks and look forward to the new DVD....
Ed M
[email protected]
So since most of you failed to read my original question I will post it again so that when someone else is trying to find out the answer they can.
"Since this is about using Greg's data I have a question about the short pulse adder. The X-axis numbers don't corespond to what is in my file so I use the closest one to it and put the data into HPtuners and it inputs a slightly different number than what I pasted. Is that normal? I don't want to do it all and find out I did something wrong. Using 42# green tops if it matters."
Pick the number that is the closest to what is in your X-axis and input the number from the excel sheet and HP tuners may input a slightly different number. This is normal.
How hard would that have been to say?
Oh and DSteck you still lost me on this "mx+b equation" thing
your answer is (yes) as stated in the other posts.. not everyone will say yes or no. when your short pulse adder changes the data that means it will not take the info your trying nor will it ever. you will have to (tune) it to best suite your needs, eg; higher number or lower number then your first input into the short pulse adder table.
hope this helps you.
[email protected]
It's a formula for calculating straight line values and would interpolate the exact values iaw with your tune axis values, but again, there are fixed step values that the PCM will factor up/down to so you will still have values which don't match.
Just insert the number from Greg's table that is the closet to your table axis values. It will look like a "stair case" when you graph it.
Ed M
[email protected]
is this dave dvd use full?
2002 Trans am Ws6
Lt's Ory 12.9
Trickflows 215's in the works!!!!!
Help me with the English I think you are asking if the DVD is useful?
The answer is yes. Besides showing the how-to set up for WB (hardware and HPTuner formulas) , MAF/VE tuning and general HPTuner operation it comes with a second DVD with all Injector info for everything from 26 lb'rs to 80 lb For injectors.
Ed M
[email protected]
It's known as the "Slope-Intercept" form: y = mx + b.
It is used to determine the formula that describes a line on an x-y plane, where:
y = Vertical position
x = Horizontal position
m = Slope of the line
b = Point where the line intercepts y.
Look here for more information.
