Results 1 to 13 of 13
Thread: Individual Cylinder Trim's
    Dec 2008
    on the Dyno
    1,716
    I use other brand software for older OBD1 LT1 applications and even those old outdated computers have a form of individual cylinder trim. I know the LSx PCM is very powerful and I'm fairly confident that there is some sort of cylinder based trim in the programming...
    Can anyone clarify?
    James Short - James@ShorTuning.com
    Located in Central Kentucky
    ShorTuning
    Senior Tuner S2H's Avatar
    Apr 2005
    4,385
    Quote Originally Posted by LSxpwrdZ View Post
    Can anyone clarify?
    thats a negative..... if it existed, we would have it, as well as several other pcm software editors...nobody has it....
    -Scott - Formerly Known as "soundengineer"
    Schexnayder Racing
    Engines, Transmissions, Tuning, Injector flowing and testing
    www.schexnayderracing.com
    or Find us on Facebook
    Dont forget to Check out Progress on my RaceCar
    Project Blasphemy
    Dec 2008
    on the Dyno
    1,716
    I did a little more research and found that they did away with it after the LT1 PCM's...
    Sucks cause it would make fine tuning a breeze aspecially for single plane's and nitrous setups. Oh well one can only wish huh.
    ShorTuning
    Aug 2008
    Spokane, WA
    209
    You could have someone like John from Fuel injection connection set you up with some injectors that flow slightly more on the cylinders that receive the most airflow. If you're plugs looks noticeably different it may be worth it. Two of my injectors flow slightly more on #7 and #8.
    Dec 2008
    on the Dyno
    1,716
    Bringing back an OLD post... There IS individual cylinder trims available on all Gen3 PCM's. Testing the binary has proven to work as intended! Gen3 PCM is a bad bitch!
    ShorTuning
    Sep 2017
    305
    Say what now?
    Dec 2008
    on the Dyno
    1,716
    Ability to adjust a fuel multiplier for each cylinder. Comes in really handy to help keep cylinders inline when pushing big power combos. Individual timing I'm still looking for, if it exists.
    ShorTuning
    Feb 2017
    410
    hoelee$hit!
    I'm curious how much power and what intake manifold design you found this to be necessary for... and any other details you don't mind sharing... have you tested it (sure you have!)
    Sep 2017
    305
    how do you go about doing somthing like this on say a P01?
    Dec 2008
    Nevada
    3,828
    Quote Originally Posted by anniversaryss View Post
    he understands the internal code and is accessing what is there and modifying the tune program to allow it to be viewed. This is deep into computer language and code. Not something you will be able to do as a standard HPTuners user.
    Standard HPTuners members would have to wait to see this feature be added which will only happen if the tech team where to agree to finding it, enabling, and modifying the vcm suite to make it user friendly.
    i should note that this is a factory table option fro the pontiac gtp ecu which is a P05b model. The feature is called "Cylinder Gain" --> "Gain vs. Cyl"
    if you beg nicely they may include it.
    rdrfabrication@gmail.com
    2016 GMC 3500 Denali Diesel
    Ecotec help can be found here:
    LNF-http://www.hptuners.com/forum/showth...357-LNF-Guides
    LSJ-http://www.hptuners.com/forum/showth...965-LSJ-Guides
    Jun 2007
    Finland, Europe
    401
    Thank you!
    Sep 2017
    305
    Awesome thanks guys..
    Dec 2008
    on the Dyno
    1,716
    The P01 I've not located yet. Still a work in progress on them. May not actually exist on the P01 but I'm going to keep digging. If this is true then this is one more reason the P59 is a good PCM to swap to.
    ShorTuning
