Dennis,
The rolling idle/clutch in has definitely gotten alot better by using the Dynamic airflow as the tune model. IAC counts are much closer now (+/- 4 counts). The only unknown at this point is why I needed to move the idle scalar from the conventional (mathematical) value of .0192 for a 90 mm TB vs the current .0285 which seems to work much better.
My initial approach was to use the MAF values, but Scott's is to use the Dynamic (VE only) which can be a frustrating trying to get the 3 amego's (fuel, timing and air) to line up after each change
As Scott said, I will get her on the dyno to tweak in the VE (street tuning VE compounds the frustration for me ), tweak out the rich decel (still have a bit of oscillation in the rolling/clutch depressed idle, and dial in the cold start/warmup open loop tables on the street. With the holidays and all, I haven't had time to tweak.
Thanks Scott for your help. Dennis, give it a shot and let us follow your progress.
Ed M
