Page 1 of 4 1234 LastLast
Results 1 to 20 of 77
Thread: 6L80E 3-4 slow.
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    6L80E 3-4 slow.
    Hey guys. I've got a 6L80E in an 08 G8 GT, and on high speed WOT runs going from 3-4th it takes forever to make the Gear change. Like a good 2-3 second lag where the car just quits pulling and then it slowly makes the change and starts pulling again. I have all Torque Management Disabled and I'm doing everything via Shift Times which is going well. But, I have this issue. So what do I do to fix it? And how do you work with the shift time Inertia Adder tables?
    -Robbie.
    618/618 motor
    906/862 spray
    Senior Tuner Google's Avatar
    Sep 2010
    Saint Peters, Missouri
    1,303
    Quote Originally Posted by IDRIVEAG8GT View Post
    -Robbie.
    prolly somthn in the tune we don't see posted causing the problem.
    We Can Fix Your Bricked PCM Or Your YYYYYY OS ID
    Aug 2010
    Roswell, N.M.
    1,956
    Ok OK! I'll post the damn thing :P Happy??
    618/618 motor
    906/862 spray
    Sep 2010
    1,303
    have you tried lowering your shift rpm/mph for the 3-4? I have not study'd ur tune but will keep looking into it.. most 3-4 or 2-3 lag is a conflict in the tune some were..
    Senior Tuner Frost's Avatar
    Jan 2006
    Richmond VA
    1,950
    Does it just do it in sport mode? It's my understanding that it's supposed to happen in sport mode (at least it's the OEM's intent). It's anticipating the re-application of throttle.
    Steve Williams
    TunedbyFrost.com
    Feb 2006
    Rancho Santa Margarita, CA
    905
    OP, have you tried to replicate the issue with the stock trans tune ?
    If you load the stock trans tune, take a log where it shows the 3-4 shift and post it here. include vehicle speed,rpm, current gear, etc.
    Aug 2010
    Roswell, N.M.
    1,956
    Will get on this ASAP. Just finishing up my Cam/Heads job on it. It does it regardless of D, SD, or M. It's like it slips! I'll try loading a stock trans tune though and see what happens.
    618/618 motor
    906/862 spray
    Apr 2010
    28
    Check fluid level. I'm not sure about your specific ride but my Corvette requires that the fluid level be checked when the fluid temp is between a range of (IIRC) 78 degrees F - 122 degrees F.
    I did a H/C swap. I also had the 3 - 4 slop/slip. The fluid level was full at 170 degrees. Once it cooled down to the required temp. I found it was 22 oz. low. I filled it and the slip went away.
    Randy K
    '03 Corvette Electron Blue Metallic Coupe A4
    243 heads, 224/230 .581/.588 113 LSA Cam (416 rwhp/392 rwtq)
    CAI, AR Headers, Yank 2800 Stall, 3:42 gears.
    Advanced Tuner midevil1's Avatar
    Feb 2009
    TX
    365
    i dont know what gear you have in the diff, but you are short shifting 1-2 and 2-3 and then you have your 3-4 shift maxed on mph and a 6125 rev limit....not going to jive.
    2023 Ford Edge ST
    2020 Ford F150 King Ranch 5.0
    Aug 2010
    Roswell, N.M.
    1,956
    Quote Originally Posted by Randy K View Post
    That may be the cause. Never even thought about fluid. Thanks.
    618/618 motor
    906/862 spray
    Aug 2010
    Roswell, N.M.
    1,956
    Quote Originally Posted by midevil1 View Post
    Mmmm there's 2:92's in the diff. My first to second is good because it raps so fast the TCM can't keep up. Second to Third, I see what you're talking about. I'm addressing that. And Third to Fourth well it shifts at the right rpm it just poops out Fourth to Fifth though is good. And Fifith to Sixth, well I've only ran it to 170 with the new cam and heads so far so it's not going to poke that gear in for awhile.
    618/618 motor
    906/862 spray
    Tuner wreckwriter's Avatar
    Apr 2009
    West Virginia
    147
    Not sure what the issue is but I can tell you for sure it is in the tune. Bluecat fixed mine.
    2008 Pontiac G8 GT, IHRA Modified, NHRA Pro ET
    Jun 2009
    202
    You might have burnt up the 3-4 clutches. Based on your power level and your lack of torque management on a stock tranny, that's my best guess. The 3-4 clutch in this tranny is the weakest and usually fails first. Turn TM back on and see what happens. Leave your shift times alone and let the ECM pull timing. Good luck
    11.49 @ 118 1.49 60' Bolt on 2010 IOM Camaro
    www.6l80etuning.com 6L80/90 Tuning
    Aug 2010
    Roswell, N.M.
    1,956
    Hey guys I fixed it! Thanks for the suggestions!
    618/618 motor
    906/862 spray
    Apr 2009
    29
    What did you do to fix it?
    Aug 2010
    Roswell, N.M.
    1,956
    There was an inertia multiplier table that I set to 0 and it is perfect.
    618/618 motor
    906/862 spray
    Feb 2006
    905
    What table was it?
    Aug 2010
    Roswell, N.M.
    1,956
    I forgot but it was under "Upshift Special" Apparently it multiplied everything by 1.5.
    618/618 motor
    906/862 spray
    You can change the table to negative values if it needs any more help.
    Aug 2010
    Roswell, N.M.
    1,956
    So far it seems good, I don't want it to bang 3-4 anyways, right now it shoots it in nice and easy and there's no delay or hesitation.
    618/618 motor
    906/862 spray
