Results 1 to 4 of 4
Thread: What are these O2 parameters for????
    Dec 2004
    for now, Kandahar Afghanistan
    39
    O2 LR Average transition Time's (Got the banks down!)
    O2 Time to activity
    O2 RL-LR Transition Ratio ( and of course would be opposite of LR-RL!).
    I was logging these, as well as O2 mv, mine stayed at 0 except for time to activity, was 53/58 from a cold start. Both transition times stayed at 0 though? Is that right? BTW, my car runs fine except the bad IAC.
    Charlie
    00 NBM Z28 Rossler A3 ATI 4k TC, 347 w/ ETP 225's, EDC 231/242 .637/.622 @ 114*, LS6 Intake, Kooks 1 7/8" LTs, Wolfe 6pt, BADZ LCA, Spohn SFC & TA, Custom 2 Stage N2O. Next up, 90/90, 9" and Bogarts.
    Dec 2004
    39
    Re: What are these O2 parameters for????
    Anyone? Gees, 17 views and nothing
    Advanced Tuner 405HP_Z06's Avatar
    Feb 2004
    Arlington, Texas
    270
    Quote Originally Posted by CAT3
    This is O2 sensor lean-to-rich transition time. This is the amount of time in seconds that it takes the O2 sensor to swing from the low(lean) voltage constant to the high(rich) voltage constant. The R-L minimum value is 0.00 and the max value is .12. The L-R minimum value is 0.00 and the max value is .14. A value outside this range will report a fail condition.
    O2 Time to activity
    I would guess that this is the amount of time in seconds that it takes the O2 sensor to reach the low(lean) voltage constant.
    O2 RL-LR Transition Ratio (and of course would be opposite of LR-RL!).
    This looks to be the ratio between the amount of time it takes the O2 sensor to transition from the high(rich) to low(lean) and then low to high voltage constants.
    Charlie
    My O2 sensor R-L transition time is .05 and my L-R transition time is .02.
    HTH.
    Aaron
    Aaron
    '03 Z06 Corvette - The Normal Stuff.....
    EFI-101, EFI Advanced, EFILive-101, Variable Camshaft Tuning
    EFI University Evangelist
    Dec 2004
    39
    Aaron, thanks for the input. Appreciate it.
    Charlie
