Results 1 to 8 of 8
Thread: p0231 after dual walbros
    Jun 2009
    203
    Greetings
    I just wired two walbros to the stock power line. It shows the code even I select no error reported and dissabled the code U0109
    do you have any idea what I could do? maibe a resistor?
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    Is this a 2010 Camaro? Those Walbros aren't compatible with the FPCM. If you're going to use those, you need to convert to return style and eliminate the FPCM.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Jun 2009
    203
    no, it is a 2011 sierra. Is there any trick to stop the check engine light?
    Tuner in Training skalor's Avatar
    Nov 2002
    Lehigh Valley, PA
    33
    I'm interested in this as well as we have the same problem on my friend's 2010 Sierra with dual walbros. I don't know anything about FPCMs or if his truck even has one but it seems to work. Well, it's been like that since August and no problems besides the code.
    '89 Olds Cutlass Ciera International Coupe - '99 L67 minus the M90 plus a 60-1
    Advanced Tuner ProTools4's Avatar
    Mar 2006
    sunny So Cal
    292
    Is this a proper recipie:
    -Billet fuel rails
    -Adj return style Fuel pressure regulator
    -Aftermarket pump pump *dueal 255s or sinlge 400 Walbro
    -relayed Fuel pump wiring
    -unplug the FPCM to prevent DTC from the FPCM being reported to the VCM
    NotoriouSS TAD
    DATLS7N 73' Datsun 620 LS7/HNC/TR6060/4.10/T2/2450lbs/603RWHP
    J5 - 96' Impala SS - 4700lb autocross machine
    Langston - 96' Caprice 9C1 Beater
    Rosie - 67' El Co - race truck w/ plates
    Wall-E - 21' Tesla Model 3P
    Advanced Tuner vette_c6's Avatar
    Jun 2008
    Kuwait
    390
    same thing happened to me yester ,,
    car was leaning up
    changed fuel pump for the Car ,,
    Fuel was good ( not perfect )
    swapped the Sierra 4.8 Fuel pump with BBK internal fuel pump
    for 6.0 engine
    and same thing ! check engine sign came in ,, same code ! didnt disappear :!
    any clue ?
    specialize in: V8 Tuning (Kuwait)
    Abdullah Al-najdi
    00965 99369929
    www.youtube.com/alnajdi83
    Tuners ! Quit Raping your PE TABLE !
    instagram : alnajdi83
    best number in 1/8 mile 4.54 ( My Driving + My Tune ) !
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    Quote Originally Posted by vette_c6 View Post
    car was leaning up
    for 6.0 engine
    any clue ?
    FPCM is a little bastard. There are things you can change though so far as commanded fuel pressure and what not, but still.
    618/618 motor
    906/862 spray
    Jun 2008
    Kuwait
    390
    i guess we have to live with it :<
    Abdullah Al-najdi
    00965 99369929
