Hey guys.... This isn't really tuning related, I just need help and a how-to. What I've got is a 415CID LS3 at 10:5:1 compression with L92 heads that's going to press a maximum of 800+ horsepower, with about 13-14 Lbs of boost. The general failing of Cylinder #7 comes from heat because it's one of the hardest working Cylinders, the first one to get fuel, and it's the most starved cylinder for Coolant. Keeping this Cylinder cool is number one priority. I've done a little research and am coming up blank. What I need is a crossover steam pipe for the rear of the heads instead of using the block offs, but my issue is that it's got to fit underneath the Magnacharger or go around it or something, and then tie into the front Pipe somehow. Does anyone have anything like that? I don't think the old LS1 4 corner system will fit so I'm kinda SOL. :O
