Results 1 to 2 of 2
Thread: Manifold Gasket & Oxygen Sensor????
    Apr 2004
    4
    What's the easiest way to check for a manifold gasket leak and also if an oxygen sensor was bad, shouldn't you get a code for this? I have a 1992 s-10 Blazer 4.3 vortec - v-6.
    Apr 2003
    Almost 2000 feet.
    7,876
    Re: Manifold Gasket & Oxygen Sensor????
    Check from the cylinder head to the body of the o2 sensor with an ohm meter. It should measure less than 2 ohms. If not, it may be as simple as unscrewing it, cleaning the threads on both and screwing it back in.
    Headers are the worst for this problem.
    EC
    Always Support Our Troops!
Similar Threads
  1. O2 Sensor question
    By txoutlaw in forum GM V8 Tuning - Engine, Gas (Gen 3)
    Last Post: 11-25-2007, 11:11 PM
  2. PCM Pinout Diagram
    By jeffstar in forum GM V8 Tuning - Engine, Gas (Gen 3)
    Last Post: 08-02-2007, 03:15 PM
  3. Leaded race fuel / oxygen sensor talk
    By tunedbytad in forum GM V8 Tuning - Engine, Gas (Gen 3)
    Last Post: 10-11-2005, 11:43 AM
  4. DTC Tables
    By Casey in forum OBD-I & OBD-II Hardware And Communications
    Last Post: 08-09-2003, 01:44 PM
