Results 1 to 16 of 16
Thread: Completely Stock I6 Turbo Best low down boost
    Dec 2009
    Bayside, Melbourne, Victoria
    301
    Howdy all,
    I thought this might be a good thread to start what's the best low down boost anyone can get on a completely stock inline 6?
    I have had mine get to around 10Psi at 2500 rpm, but I have since changed cam timing & ignition timing a bit & now not getting there till around 2800 rpm!
    I need to chuck it back on the dyno & see which is actually better for torque & power!
    Cheers Grant LS1
    Dec 2005
    Sydney Australia
    510
    ill have to check some logs, but our FG can get over 20psi at a little over 2000rpm... but it has the smaller turbo
    Dec 2009
    301
    Nice work dale,
    Mine is a BA so yeah a little different, do you roughly remember what it was on a BA/BF?
    Dec 2005
    Sydney Australia
    510
    ill try it on my BA tomorrow.. still stock dump but has a cooler tho.. i think it makes 20psi at about 3500
    Dec 2008
    48
    20 psi at 2000rpm lol who needs a blower!
    Dec 2005
    Sydney Australia
    510
    yeh but its all over at 4000rpm and boost is back to 13psi by 6000rpm...
    a simple turbo upgrade netted over 70rwkw gain at 6000rpm with a peak of 16psi... so 5psi less boost...
    Dec 2005
    Sydney Australia
    510
    20psi at 2800rpm on my car..
    Dec 2009
    301
    Far out, so I'm assuming you have injectors, springs & the intercooler?
    Anything else ie: Zaust, CAI etc...
    Dec 2005
    Sydney Australia
    510
    It's got springs, stock dump with a 100cpi cat and dual 2.5in, fuel pump and injectors,
    Going to put some fg cams in it next week. Got the tune pretty consertive and it makes 320 all day long... With the fg cams it should got 330 or so on 16psi
    Dec 2009
    301
    Nice!
    So you can use the fg cams in the ealrier girls, do you just use the FG gears & then run the fg cam timing too(with mods).
    Dec 2005
    Sydney Australia
    510
    I'll tell you in a few weeks.. But I'm pretty sure it just bolts together..
    Feb 2010
    Perth Australia
    480
    Mines make 7psi @ 3500 rpm............Not that impressive. Cept the car aint moving when it does it. A little cam and Ign retard and a few tweaks too the rev limiter makes for a nice launch system
    04 Velocity MKII M6 & 06 BF F6 555 ZF6
    Dec 2008
    48
    Do you prefer the BA power over FG Dale?
    Dec 2005
    Sydney Australia
    510
    fg with a bigger turbo is the best
    Jul 2009
    326
    Well it will depend what gear you're in to start with. 4th gear will boost earlier than 2nd. In any case closed loop control will get you there earlier in all gears.
    Dec 2005
    Sydney Australia
    510
    that was in 3rd gear on the auto...
