Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
Thread: 24x to 58x converter?
  1. #21
    May 2020
    7
    Yes, I double checked timing with a timing light against what the computer reads.
    2011 Charger R/T 5.7L
    -Corsa cat back with mid muffler delete
    -Sprint Booster
  2. #22
    May 2020
    7
    I have the oem crankshaft from the 6.2l, with the reluctor still a This is where I took my measurements from. I found tdc#1 and basically measured the offset I needed. I can send you pictures and videos if you need. Or you can call me 6672210662. I saved blue prints to my sensor bracket as well.
    -Sprint Booster
  3. #23
    May 2020
    7
    You followed the directions by someone that has one post and no evidence that it actually worked. Crank position sensor isn't just for picking up rpm, hence the "position" in the name.
    https://youtube.com/shorts/Vmdj7-hTX...NVHHkTGFYJMbcS
    -Sprint Booster
  4. #24
    May 2020
    7
    -Sprint Booster
  5. #25
    Nov 2017
    2,633
    I'm not saying it can't be done. If you have a good enough way to measure it, I'm sure it can be done. But pretty obvious that Daniel566 was missing a big piece of the puzzle.
  6. #26
    May 2020
    7
    Quote Originally Posted by Daniel566 View Post
    Im having this same issue on a 2006 trailblazer with the 5.3 got a motor out of a 08 ltz truck. I have followed your steps welding the 58x wheel to the back of the harmonic balance pully and made sure it was level and got a mount made for the sensor and it's gapped right with feeler gauges. It's still not starting, do you have to time the reluctant wheel to the crank position sensor?
    You took the engine out of an 08 and are putting it in an 06 envoy? Or the other way around?
    -Sprint Booster
  7. #27
    May 2020
    7
    Only tools I used to measure angle was a protractor and a sharpie. The fact that the crank isnt keyed actually made it easier, because you can place it at any angle. Just get it close and make minor adjustments base on where you mount the CKP sensor.If I'm reading correctly, i believe his situation is the opposite of mine. In which case I would just buy the conversion harness
    -Sprint Booster
