Page 1 of 3 123 LastLast
Results 1 to 20 of 60
Thread: Standalone logging not working.
    Jan 2011
    29
    I had my MVPI Pro for about a week now and logging to the laptop is working
    great however I cannot get it to log in standalone mode. I have followed the
    instructions in the "MPVI Pro Standalone Data Logging" section of the help
    file, another set of similar instructions I found on a form, and I
    even took the MPVI in the house and set it up with a table of only about 10
    things I wanted to log for an autocross. Still nothing.
    When connected to the PC I have a power light and see the busy light flash
    if I am saving configs or clearing the logs. There is no power light with
    the car running and the MPVI plugged into just the OBD II port (not the USB cable).
    I have version 2.22.3152.18236 & 2.23.147 Beta on two laptops both running W7. I have the separate drivers downloaded and installed on both.
    I have tried different times holding the record button down from less that a
    second to 1, 2, 3, 4 and more seconds.
    I have read the VCM and saved the file from my 2005 Cavalier but have not
    licensed anything yet. From what I have read this should not be an issue.
    Am I missing something? If I am you can just get me a link or the page in
    the instructions and I will give it another go.
    ---below is the reply from support---
    We recently found that our spi chip maker(the chip that holds the standalone
    datalogging memory) changed the chip id number, we are working on a fix for
    this via a firmware update.
    HP Support (Bill) also said that he has seen this issues effects serial numbers that start with 1120 & 114X.
    I was sent 2.23.150 beta to fix an issue with the VCM Scanner not reading older (2.22) log files. The log file issue has been fixed but I have not tested the standalone logging yet.
    Advanced Tuner louvered97gtp's Avatar
    Nov 2007
    Southern California
    202
    I have the same issue. I've never been able to have use the stand alone feature on my Pro interface. So is the fix, a software update to the scanner software?
    99GTP: Flowmasters, ZZP Power log & Ported rear, 9.5:1, Bored over .010, removed balance shaft, Dbl roller chain, Intense S1X, custom ported heads, 45#inj., 105lb springs, 1.7 rockers, A103's, 180-stat, Gen V swap, 97 Cadillac TB & Custom machined alum. spacer, 95 GTP Hood louvers
    97GTP: Stock engine, 95 GTP Hood louvers
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,275
    Ultimately it will be a firmware update as its not a software issue for the most part, basically the company we purchase our memory chips(spi chip) changed the PN of their chip so when our hardware polls that chip the chip returns a different PN and says "not happening", we're working on finalizing the firmware update this week so hopefully all goes well.
    -Bill
    -Bill
    I'm waiting for this update.
    Nov 2007
    Southern California
    202
    -Bill
    Quote Originally Posted by BlurrSpeed View Post
    FYI, My interface (serial# starts with a 105030), in case that info. is relevant.
    HP Tuners Support
    (foff667)
    28,275
    Quote Originally Posted by louvered97gtp View Post
    In that case your interface is not affected and you should contact support.
    Tuner in Training sreve's Avatar
    Jun 2008
    35
    I have this problem also serial starts with 1120824
    is this one affected also?
    never mind just saw this:HP Support (Bill) also said that he has seen this issues effects serial numbers that start with 1120 & 114X.
    will the firm ware update be separate of 2.24?
    Sep 2002
    Chicago, IL
    6,395
    This issue is our top priority and is what we're currently working on.
    I don't have an ETA for a fix yet but we hope to have this ready ASAP.
    We got this guy Not Sure, ...
    Mar 2007
    12
    stand alone logging
    I have the same problem and observe the same responses from the interface when attempting to stand alone log
    Jan 2011
    22
    Bummer, I can't get mine to work either. My serial number starts 11471xxxxx
    I can't leave the laptop on the seat at the track. Any other work arounds?
    Nov 2002
    Central Florida
    2,503
    Well, I have my EIO running through a 12-foot USB cable.
    Plenty long enough to let the laptop go behind the seat
    on the floor.
    HP Tuners Support
    (foff667)
    28,275
    Keith has been testing some new firmware and will hopefully have the final results(yay or nay) by the end of next week. From there we'll likely stuff it into an old build so we don't break anything in the current beta program.
    -Bill
    Tuner bigboykilroy's Avatar
    Apr 2007
    Aurora, Ohio
    131
    My serial Number starts with 1036xxxx
    No issue thus far.
    98 TransAm WS9 Raim Air โ€“ Stage 4 4L60E Trans -3:90 Rear -1.8 HS Rockers - Full UMI Suspension โ€“ 85MM Lid โ€“ 85MM Z06 MAF - LS6 Z06 Intake - 224/230 Comp Cam - 7.350 Push Rods - 243 TEA Stage 2 LS6 Heads 61cc - Melling 10296 Oil Pump - Caddy Race Lifters - SLP Underdrive Pulley - 160 Thermo - 42# Green Top Injectors - HPT - SLP Line lock - Pacesetter LTube Headers - Yank SS4000 - 98 to 2002 PCM Swap www.mrk-motorsports.com
    May 2009
    20
    Any progress to report? Yay or nay? My better half doesn't like when i still the laptop for the day's trip to and from work where I get my logs from. Thanks
    HP Tuners Support
    (foff667)
    28,275
    The firmware is done & tested and just need to compile it into a software build now, likely sometime next week from the looks of it.
    Mar 2011
    San Luis Son Mexico
    43
    stand alone ยท1156
    Im also having some trouble with my standalone pro mine starts with 1156 does it apply or am I doing something wrong
    HP Tuners Support
    (foff667)
    28,275
    Yes it would apply to yours.
    HP Tuners Support
    (foff667)
    28,275
    Theres a new beta ready that I've sent out to a few people but if you have immediate access to a vehicle that you can test on(I really need it tested ASAP) please email support with a link to this thread and your serial number and I'll send you the update but I really need results quickly so I can send it out on a mass basis.
    Thanks,
    Bill
    HP Tuners Support
    (foff667)
    28,275
    Well, preliminary results are good, first test case reported they were able to standalone datalog without issue so all systems go from here on out.
    Sep 2010
    8
    Hi Bill, I'm currently at work and don't have my serial number with me but I'm quite sure my MPVI unit is affected by the CPU name change issue. I bought it via Summit around October 2010.
    Is your fix available in a firmware 114 download like I saw elsewhere on the forums or do I need to download 2.23 beta to get the fix?
    Thanks - Jon
