Hello everyone I have a EFI connection bench harness and a windows 7 laptop. I fries my MUX chip in my interface. I am not saying that the Harness is a problem but I have decided to install a fuse inline before the control box switch. I was wonderiing if I should also add a switch to the ground wire feeding the box because as soon as I plug the harness into the wall or connect it to my batterie (I modified it to accept either a wall plug or a jumper from a batterie) the OBD port is live, adding the fuse should protect the whole harness including my ECM and ODB port(interface) the switch would act like an ignition swith that I could control better than just pliging in and un pluging. If anyone has any other thought on the subject I would appreciate it.
Also if I do not add this swithc is there any spacific order I should be connecting all my devices so I do not have this problem with the MUX chip again.
Just another note about the wiring on the original setup for the Harness. The odb and ecm have a live wire (orange) connected as soon as the harness is connected to power and when the switch is fliped it has a an ignition wire(pink)
Thanks for any advice.
