Page 1 of 8 12345 ... LastLast
Results 1 to 20 of 152
Thread: Zeitronix WB Settings in v1.5
    I hooked my Zeitronix WB up the v1.5 Cable and there is no pre-configured choice in the drop down. Does anyone have the configuration for this WB unit.
    2002 Quick Silver Z06 - Breathless Performance Shifter, DynaTech Headers SwainTech Coated, A&A Vortech Kit
    May 2003
    Santa Clarita, Ca
    1,412
    Re: Zeitronix WB Settings in v1.5
    All I see on their site is a cute picture of the output.
    It also appears to be a non linear output, so you will have to use
    the list function under "configure user defined".
    Is there anything in their documentation?
    Ken
    No I didn't see anything in there documentation. What do I need to ask for in my email to them?
    May 2004
    South Elgin, IL
    32
    From the Zeitronix install guide:
    V AFR
    0.15 9.7
    0.31 9.9
    0.46 10.1
    0.62 10.3
    0.78 10.5
    0.93 10.7
    1.09 11
    1.24 11.4
    1.4 11.7
    1.56 12.1
    1.71 12.4
    1.87 12.8
    2.02 13.2
    2.18 13.7
    2.34 14.2
    2.5 14.7
    2.65 15.6
    2.8 16.9
    2.96 18.5
    3 18.8
    3.12 19.9
    3.27 21.2
    But I'm still trying to get it to work.
    I checked with a meter and I have around 2.6 volts at idle coming from the Zeitronix analog out. I've connected it to the EIO white wire and entered the above in User Defined 1 but my chart stays at zero. I then connected the ground from the Zeitronix box (brown wire) to the ground from the EIO (blk) but still no readiing. Finally I tried using the 5v out from the EIO back to the white EIO wire and again, the chart showed zero. I also tried Raw Voltage and it remained zero. ???
    May 2003
    Santa Clarita, Ca
    1,412
    You did not enter the list data correctly. Detailed instructions are in the help file, but here is a quick sample.
    You have 51 points in .1v increments. If the list is entered correctly, you will have a sample graph in the right hand of that window.
    Your list should look like this:
    (Give it a name so you can find it, then click save)
    0,0.00
    0.1,0.00
    0.2,9.70
    0.3,9.90
    0.4,10.00
    0.5,10.10
    0.6,10.30
    0.7,10.40
    0.8,10.50
    0.9,10.70
    1,10.85
    1.1,11.00
    1.2,11.40
    1.3,11.55
    1.4,11.70
    1.5,11.90
    1.6,12.10
    1.7,12.40
    1.8,12.60
    1.9,12.80
    2,13.20
    2.1,13.45
    2.2,13.70
    2.3,14.20
    2.4,14.45
    2.5,14.70
    2.6,15.60
    2.7,16.25
    2.8,16.90
    2.9,17.85
    3,18.80
    3.1,19.90
    3.2,20.55
    3.3,21.20
    3.4,0.00
    3.5,0.00
    3.6,0.00
    3.7,0.00
    3.8,0.00
    3.9,0.00
    4,0.00
    4.1,0.00
    4.2,0.00
    4.3,0.00
    4.4,0.00
    4.5,0.00
    4.6,0.00
    4.7,0.00
    4.8,0.00
    4.9,0.00
    5,0.00
    On the no reading issue, are you positive you have the user defined
    data in the scanner table window? The charting data comes from the data in the table which is the master list.
    Make sure you have the right input selected on the table. There are 4 windows. 1 for each input channel.
    Email me the instructions so I can make sure you have the right wires connected.
    Ken
    May 2004
    South Elgin, IL
    32
    I copied the values from the Zeitronix install sheet, not from HPT. I was at my desktop which doesn't have HPT installed. You're table is what I have configured with my HPT.
    I just double-checked and I only see the AUX options in the chart view. I only see the standard options in the table view (no aux or WB options as described in the help file.) This is while connected but not scanning with my EIO cable.
    May 2003
    Santa Clarita, Ca
    1,412
    Only the six bottom cells on the Table Display are for wide band and output control.
    On the Enchanced IO section in the help files, do you see the picture of the cells? The cells are blank until you right click and insert something in there.
    Post me a screen shot of your table display.
    Ken
    Windy City
    Where did you get the install guide? Mine didn't come with anything like that.
    May 2004
    South Elgin, IL
    32
    It was a green paper document that came with the unit. I also remember someone scanned it and posted it on thirdgen.org. I'll see if I can find it for you.
    Ken,
    Thanks for the help. I jumped the gun and didn't completely read the directions so I didn't catch that the bottom cells corrilate to a particular input.
    However, I do have one last thing to ask about. If I choose user defined (configured for the Zeitronix), the table view works fine now but I can't choose WB (accurate) in the histogram view. If I switch the cell to one of the pre-defined WB's, I get the option. Is there a way to make it read WB? I couldn't find the answer in the help file.
    Thanks again.
    May 2003
    Santa Clarita, Ca
    1,412
    Quote Originally Posted by Windy City
    Somehow I don't think you are the only one who does that.
    The instructions are the last thing I read.... right after I screw it up ;D
    My Wife says it genetic....
    On the histogram we are going to have to add native support for that unit. Then it will work.
    If anybody needs help with this stuff, don't hesitate to ask us.
    Ken
    I think that may be my problem with my FJO Unit
    LMAO after reading and looking at the picture i see where i went wrong....
    Aug 2004
    44
    Ken, you mean that histograms only work for pre-defined units? Any plans to add FJO?
    John
    john the FJO unit isnt linear so they wont be adding it and we will have to do so manually. If you trade in your old unit for the 3001 unit (I have the CWC0001 pr something like that) this model has a linear output, this can be added via formula and prolly added for native support. As it stands with the old FJO the one i have and prolly you we will have to enter the data manually via the chart.
    YOu can trade in your old unit for the new unit. I posted a link and some information on it a few days ago.
    The new units software is was better and has a load more features for a limited time it will only cost us shipping to get an updated version. I will be sending mine back on monday.
    Here is the link http://www.fjoracing.com/products/wb...20trade-in.htm
    May 2003
    Santa Clarita, Ca
    1,412
    Quote Originally Posted by johnt
    John
    Correct on the histograms.
    And yes we can add the non linear support. The software was written to accomodate this. Some Mfgrs were a little late in supplying us with their info.
    Give us a few days.
    Ken
    May 2004
    South Elgin, IL
    32
    Is there any more info you need to add the Zeitronix WB?
    You guys are the best!!!
    May 2004
    South Elgin, IL
    32
    Ken, any idea when we may see an update with the Zeitonix WB native? Not trying to rush you, just asking. ;D
    I have the Zeitronix wideband and was able to get it to work with EFI Live. I had to get the actual formula from them to make it work though. Here is the formula I received from them.
    AFR=0.627*V ^2 + 0.457*V + 9.7758
    If you have any questions, let me knowl
    Chad
    Aug 2004
    Franklin,OH
    210
    Well it seems there is no way to enter the above formula and without the histogram WB capability it is hard to tune in a one man situation. Anything yet guys..... we are getting desperate.
    Any progress on the Zeitronix WB intergration?
    Check this out guys.
