Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
Thread: Help logging boost
    28,265
    I'm fine, just took a few days vacation so I didn't loose them before my "anniversary" date
    4 years with hpt as of yesterday
    Apr 2007
    Los Lunas, Avondale
    78
    Awesome, congrats on the 4yrs
    I have 3 at my job.
    Glad to hear everything was ok, thought I heard somewhere that you were leaving for a while for family reasons, rumors suck.
    So if I delete my cfg I wont loose my user config inputs like my wideband?
    2002 NBM WS6
    APS F-BODY TWIN TURBO KIT
    317 Heads
    60# Mototron Injectors
    HPTuners tuned by Sean@Solid-Technology, Abq NM
    610 RWHP DYNOJET on 7.9PSI
    28,265
    You'll loose your custom pids(I think your boost pid is causing the issue)
    Apr 2007
    Los Lunas, Avondale
    78
    I will give it a try, thanks again.
    2002 NBM WS6
    317 Heads
    Apr 2007
    Los Lunas, Avondale
    78
    Its reading boost just fine, delete your VCM Scanner.cfg file and then open the scanner and you will see this as well.
    I deleted my config as you asked and it is still showing boost where I had vacuum and very high boost where I was only at 1-3psi. the whole scan I only went up to about 3.xpsi on my guage.
    Any other info?
    I can email you my .hpt if that helps as well.
    2002 NBM WS6
    317 Heads
  6. #26
    28,265
    Thats the only file that would affect it, if its still reading off I have no idea what the issue is because it reads fine for me.
