Results 1 to 19 of 19
Thread: No MAF or Histograms? 02 Sunfire 2.2L
    Apr 2007
    Los Lunas, Avondale
    78
    Is there anything I need to do to make my histograms and MAF log on the scanner?
    2002 NBM WS6
    APS F-BODY TWIN TURBO KIT
    317 Heads
    60# Mototron Injectors
    HPTuners tuned by Sean@Solid-Technology, Abq NM
    610 RWHP DYNOJET on 7.9PSI
    28,264
    Need an infolog(via the vcm scanner) & the .hpt file from the vehicle.
    Apr 2007
    Los Lunas, Avondale
    78
    at work for now I will post those up as soon as I have my tuning laptop in front of me.
    2002 NBM WS6
    317 Heads
    Advanced Tuner imphat0260's Avatar
    Jan 2006
    STL
    537
    Quote Originally Posted by FIL131 View Post
    This car is not equipped with a MAF......
    P&P Tuning
    Apr 2007
    Los Lunas, Avondale
    78
    2002 NBM WS6
    317 Heads
    Apr 2007
    Los Lunas, Avondale
    78
    Quote Originally Posted by imphat0260 View Post
    Well that explains that question. I hadnt even looked under the hood.
    So these are speed density from the factory?
    2002 NBM WS6
    317 Heads
    28,264
    Yes.
    Jul 2010
    371
    No they are a retarded mix of speed density and alpha-n. Spark, idle, and coast down are speed density. Low RPM and High RPM fueling are alpha-n. I want to strangle the whole GM tuning department and cut their dicks off with a rusty spoon (not in that order) every time I think about this car.
    1994 Mazda Miata turbo, aero, hoosiers Class=SSM
    Take my drop box referral and we both get an extra 250 Mb free!
    Sep 2009
    346
    Oh yea, I had fun with a 1998 2.2... I hear ya Leafy.
    Apr 2007
    Los Lunas, Avondale
    78
    any reason my histograms arent working? Spark retard, advance...
    2002 NBM WS6
    317 Heads
    Jul 2010
    371
    Like just not working right (ie only showing stuff in 1 column but not others that it should), sitting there like they should work and not showing anything, saying that the parameters aren't supported? The first 2 I would say to upgrade to beta, that fixed some of my histos not working right (like decel). If its the last one are you sure you setup the histos while the scanner thought the car connected was a cavalier? I'll tell you that if I set up histos in default camaro mode then none of them will work on a cavalier even though the table may be the same. its weird.
    Apr 2007
    Los Lunas, Avondale
    78
    Quote Originally Posted by Leafy View Post
    I am using 2.23.261 I believe this is the latest beta. I have attached a screenshot of my scanner screen.
    I am getting not supported, but they are working on the guages... I think I started with the Default Imperial, but I am not 100% sure.
    2002 NBM WS6
    317 Heads
    Jul 2010
    371
    yeah connect to the car or load a log of the car then make your histograms.
    *wait it shows that you did that. Weird.
    28,264
    Because you are trying to setup an unsupported table, your histogram configuration screen will CLEARLY show this.
    The histogram consists of 2 main parts.
    A table or, for custom histograms, 2 axes
    The Data you want to view ie spark advance(sae)
    The data to allow you to PLOT against a table or two specific axes ie RPM vs MAP or RPM vs TPS or what have you.
    If you are missing any ONE of these items it will break the histogram.
    In this case you have a table meant for a 2002 Camaro/Firebird selected(which is the default vehicle) rather than a table for YOUR application.
    Apr 2007
    Los Lunas, Avondale
    78
    Is there any way I can have you guys walk me through this? Obviously I do not know the steps needed to scan a car other than an F-Body...
    I have completely uninstalled all of my HPTuners and reinstalled it, so I am ready to start fresh...
    I can start emailing support if needed since this is a beta.
    I have no problems tuning my NA F-body, but I am lost when it comes to other vehicles.
    Thanks everyone for all of your help
    2002 NBM WS6
    317 Heads
    Jul 2010
    371
    Ok plug into the car. Then make your histograms, and put the correct parameters on the chart view.
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    This should get you started. You need a wideband for the AFR histograms to work.
    Russ Kemp
    Apr 2007
    Los Lunas, Avondale
    78
    Quote Originally Posted by Russ K View Post
    Russ Kemp
    I have a wideband and can tune my Z28 and TA WS6 no problem, but tuning other cars has been a problem for me. Getting my boost to show correct numbers is also an issue I cant seem to correct.
    2002 NBM WS6
    317 Heads
    Apr 2007
    Los Lunas, Avondale
    78
    If I plug into the car wont it load one of the configs that are already in place?
    I have to start somewhere on some type of config right?
    I will give Russ' a try, but I really need to know how to set them up for myself too. I know this is easy once you get it but I just cant seem to wrap my head around it all.
    2002 NBM WS6
    317 Heads
