Nothing's ever easy - thought changing the flow rate tables would be as simple as copying the data I used for the 60s in my IRL, only to find out that the IRL flow rate was based on the Vacuum kPA and the G5 is using fuel pressure delta...I'm at a loss for how to convert the data over properly, so these things are working properly.
Any guidance would be appreciated.
