I have changed the tables in WOT shift to lower rpms, saved and uploaded the tune withoug success. The scanner (and my ET) are showing no change in shift rpm. Am i missing something? I am using 2.23 beta
1. This belongs in the transmission section.
2. You must lower both WOT RPM and shift speed in both the Normal Tables and WOT tables of your transmission.
Gray Ghost- The abomination. 2007 Chevrolet Silverado CCSB. 98mm turbo, nitrous, 428LSX, Rossler 80E with a brake. Finally finished. 23 psi, no numbers, Slow as hell.
PBM G8- Aluminum 364, twin Precision 67/66 turbos, 6L90 trans swap, CTS-V/Vaporworx fuel system, slowly making progress.
Dads 2011 CTS-V- Stock bottom end, stock heads, LS9 cam, pullies, ported blower, ported TB, D3 goodies, and lots of nitrous.
618/618 motor
906/862 spray
Caterpillar 50 Forklift- Duramax swap
Did you change the downshift points at the same time?
Rob
If you have a 4l60e (or similar), I've got an excel spreadsheet that can help you out. Let me know and I'll send it to you.
07 Z06. Stock LS7 Bottom-end, Katech Torquer 110, ARH LTs w/Cats, Halltech KBII CAI w/Beehive, 160* t-stat.
